Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: Cheap upgrade for COMP based 2.2 Clod....
Old 08-13-2006, 11:04 PM   #41
TLTCrawlin's Avatar
The ziptie is connected to a servo that pulls the motor real tight, making the motor not roll because of the major tight mesh!
TLTCrawlin is offline   Reply With Quote
Old 08-13-2006, 11:25 PM   #42
Originally Posted by SVEN
So if the micro servo pulls out a brush and cuts power to the motor, then all we need to know now is how the axle is locked to keep it from rolling.
Why? 3 of us used it today at the Comp on our 2.2 Clods. None of us had any issues with the rig wanting to keep rolling when the dig was in effect. There is enough drag in the gear case and at the motor to effectivly hold the rig there for that 5 seconds you need the dig. Also adding CVD's to the front really help too, that tighter turning radius makes the dig even more impressive.
Setting up a brake system could be done but so far the 3 of us that are running it don't see a need for it.
You smoke too much wacky-tobacky.... it's obvious you can't read either. The servo is zip-tied to the motor.
toyofast is offline   Reply With Quote
Old 08-13-2006, 11:37 PM   #43
TLTCrawlin's Avatar
Oh, I misread that! I know I smoke too much wacky-cracky!
heres a the new version of my thinking!
The servo is on the motor, ziptied down, there is a cable on the servo horn that is connected to a mount, link mount, 3rd link mount, etc, and the servo horn pulls the motor inwards making the mesh tight! LOL that was the same idea, just different point of view!
Old 08-14-2006, 05:27 PM   #44
SVEN's Avatar
[quote=toyofast]Why? 3 of us used it today at the Comp on our 2.2 Clods. None of us had any issues with the rig wanting to keep rolling when the dig was in effect. There is enough drag in the gear case and at the motor to effectivly hold the rig there for that 5 seconds you need the dig. Also adding CVD's to the front really help too, that tighter turning radius makes the dig even more impressive.
[quote]
Interesting, I had no success with cutting the power to the motor with out locking up the wheels. My front end would just pull the rear along with it (no dig). I guess I will have to go try your method out and see if it works any better than my current setup.
SVEN is offline   Reply With Quote
Old 08-14-2006, 05:37 PM   #45
Bushings lubed with epoxy, superglue, and moose slober?
Highmark is offline   Reply With Quote
Old 08-14-2006, 09:37 PM   #46
That is a great idea. Nice and simple.
When I get my 2.2 Clod built (next 14 days) I will show everyone a way that this can be done using any Stock TQ3 or similar, but much more effectively then this, and for only $20ish.
I am not ready to say how I will do it till I test it, so I need to build a Truck (I only have my Unlimited Clod and a bunch of TLTs right now and the setup will not work on those)
renoirbud is offline   Reply With Quote
Old 08-15-2006, 06:55 PM   #47
So when are we going to have a write up with better pic's?
Old 08-15-2006, 07:08 PM   #48
After Moab. I work 6 days a week, still at work as I type... we are in the process of moving so the last thing on my mind to the RC's, okay well not really but it should be.
Let me finish putting my front axle back together.
Old 08-15-2006, 10:59 PM   #49
Maybe you should give some credit where credit is due. BIATCH.
Sean
hackster is offline   Reply With Quote
Old 08-15-2006, 11:03 PM   #50
Sean
Your gay. I thought of it, I am king.
Naw.... I'm to much of a push over, Hackster is the master at cheap tricks. This is his idea, although I never actually saw it in person before I installed mine, just a quick description over the phone. His works much better than my 30 second booty fabbed up setup.
Are you coming by my work tomorrow? I want to compare tan lines.
Old 08-16-2006, 10:57 AM   #51
I am going to try to swing by this afternoon. Time is really tight. Gotta go to the dump, get the jeep off the trailer, then get the toyota ready to go to head to mogfest tomorrow.
Hope fully I can swing by, if not Ill get the stuff to you on friday.
Cool?
Sean
Old 08-16-2006, 11:33 AM   #52
CSR
Are you going to the dump to pick up a Jeep or drop one off?
Damn, guess I have to "keep up with the Jones'" and put dig on my 2.2" before Moab..... :?
CSR is offline   Reply With Quote
Old 08-16-2006, 12:29 PM   #53
PapaGriz Yo
Grizzly4x4's Avatar
I never woulda thought of disconnecting the motor like that!
Front dig is a good idea to have CSR.
Grizzly4x4 is offline   Reply With Quote
Old 08-24-2006, 08:10 PM   #54
What is a front dig??
dezrik is offline   Reply With Quote
Old 08-24-2006, 08:22 PM   #55
dezfan's Avatar
Search *front dig*
dezfan is offline   Reply With Quote
Old 08-24-2006, 08:31 PM   #56
just did and i found nothing! Just tell me instead of adding another reply!
Old 08-24-2006, 08:37 PM   #57
dezfan's Avatar
comp style tlt (GROUNDER) with front digg
It is the ability to lock your rear drive wheels. Turning in the direction you wish and applying throttle let your crawler pivot and make extremely tight turns.
Old 08-24-2006, 11:57 PM   #58
I installed this mod on my 2.2 TS clod and holy carp, I'm a believer.
camel_rc is offline   Reply With Quote
Old 08-26-2006, 06:18 AM   #59
For some reason I'm not getting it all. The servo pulls the neg wire off the motor right?
Old 08-26-2006, 11:44 AM   #60
No. About 20 posts up, posted by SVEN.. it says what happens. Reading is good
