Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: Vintage Clodzilla w/operable snow plow
Old 02-15-2012, 06:14 PM   #1
Default Vintage Clodzilla w/operable snow plow
Dug out my '93 vintage Clodzilla and made a few chassis and suspension mods. Still running the original Sapphire 17 T motors with a Novak Super Duty esc. and 4 wheel steering. I recently made the operable snow plow. Still need to paint the VW bug body.
Clod Operable Snow Plow - YouTube
Gumbajv is offline   Reply With Quote
Old 02-15-2012, 07:31 PM   #2
Default Re: Vintage Clodzilla w/operable snow plow
Thats pretty damn cool Gumba, post some pics of your plow setup. Welcome to the board BTW.
kdrodworks316 is offline   Reply With Quote
Old 02-15-2012, 08:59 PM   #3
Here ya go. The front servo mount holds 2 servos, one for the steering and one for the platform lift. I used 2 Kyosho Blizzard blades to make one 16" wide one held in place with an aluminum frame. The servos are from Crawford. [IMG][/IMG] The wheels have 5/8" spacers for more steering clearance.
Old 02-28-2012, 12:57 PM   #4
Badass stuff! I love vintage Clods. I've had two of them over the years (an original, and a super Clod), and I really miss them both!
thisdougsforu is offline   Reply With Quote
Old 03-04-2012, 07:44 AM   #5
Here's a shot of the Clod. Some of the mods include removing the 4 lower links and a couple of the vertical links, and switching to a 4 mount upper link system. Also made a new center section. The servos are mounted next to trans. The servo mounts can hold 2 servos and are tied into the center upper link post. The inner servo is for the steering, the outer servo on the front is for lifting the snow blade. A second servo can be mounted on the rear servo mount for some type of tow truck crane. The rear servo mount has a 3 mm threaded hole so you can lock out the rear steering and not remove the servo. The wheels have 15mm spacers for more turning clearance.
The next project in progress is a track system that retains the 4 wheel steering.
Old 03-08-2012, 01:45 PM   #6
really nice, a clodzilla 1! Cool stuff dude!
roog909 is offline   Reply With Quote
Old 01-06-2013, 06:53 PM   #7
Thought I'd up date this. I switched to Integy 55T motors w/9T pinion, differential lockouts, Holmes esc, Gmade shocks, Hot Racing steering blocks. I made a set of 3.8" aluminum wheels so I could use the paddle tires for more traction, and finally painted the body.
Old 01-19-2013, 08:03 AM   #8
looks great! Those wheels are awesome! Any closeup pictures of the wheels?
hobolarry is offline   Reply With Quote
Old 01-19-2013, 04:14 PM   #9
Vintage Clodzilla w/operable snow plow - Similar Threads
Snow Plow mrtwister75 Axial SCX-10 8 02-06-2010 05:45 PM
RC Snow plow 01XJ Chit Chat 10 01-07-2010 09:46 PM
Snow Plow TwistedCreations General Scale Talk 7 12-27-2008 03:25 PM
Anyone use a snow plow? ProfitOfDoom Tamiya Txt-1 and Juggernaut 11 10-18-2004 07:32 AM
