Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: My RCP Crawlers Hustler (pics!)
Old 01-24-2007, 12:21 AM   #1
Default My RCP Crawlers Hustler (pics!)
thanks to brian, nathan, jason and noel for the help/ideas/advice!
here are the specs of the mysterious, never photographed hustler!
RCP Crawlers hustler tube chassis. chassis is painted gloss black. the panels are flat black(of course!) with pinstriping and hand lettering by me. these pics don't do it justice. lots of cool details hiding on the chassis.
thunder tech CVD's, narrowed axial wheels, aluminum spools, moab XL's, hot bodies shocks with internal springs.
integy hand wound 60 turn motors, mamba max esc, A-123 9.9v battery, airtronics 94359Z servos, all controlled by an airtronics M8 with spektrum.
i had a chance to wheel jason's hustler at the last so-cal comp. made a believer out of me real quick! the hustler is available only from RCP Crawlers Inc. check them out at http://www.rcpcrawlers.com, or contact Rockpiledriver.
gregrocks90046 is offline   Reply With Quote
Old 01-24-2007, 12:34 AM   #2
mjh
Talking
No matter what I say it wont be a good enuff compliment
mjh is offline   Reply With Quote
Old 01-24-2007, 12:37 AM   #3
Release your anger..
ThinkTank's Avatar
yay,the hustler revealed at last!
hey gregrocks ,do you have the A123 Turbo module on it ?
Any action Pics?
ThinkTank is offline   Reply With Quote
Old 01-24-2007, 12:45 AM   #4
Any action Pics?
no action pics yet, just finished it tonight.
i don't own the turbo module, but i've tried it! pretty neat! i recommend the A-123 9.9v pack for any super class rig.
Old 01-24-2007, 06:30 AM   #5
Nice setup.Where did you get the allum. spool?
joesbruiser is offline   Reply With Quote
Old 01-24-2007, 06:40 AM   #6
Nice to see yours totally complete.
Q:
What weight (if any) oil, are you using in your shocks?
I emptied mine, when I put the springs in.
raytard is offline   Reply With Quote
Old 01-24-2007, 06:48 AM   #7
Kool I like the hustler even more now....
Brandon M is offline   Reply With Quote
Old 01-24-2007, 07:08 AM   #8
The rig looks awsome. As for what oil to run the shocks I have found that 100 wt. Works very well. It slows down the suspension and makes it less likely to unload on the verts or of camber stuff. This is how we also set up are 1:1 rig.
bastard is offline   Reply With Quote
Old 01-24-2007, 07:17 AM   #9
Thanks.
Old 01-24-2007, 08:01 AM   #10
thanks guys!
and i am running 100wt. shock oil per jason and aaron's suggestion.
Old 01-24-2007, 08:36 AM   #11
raul duke's Avatar
Just had to do it didn't you. Gonna make it hard to get even close to you now at the comps. Thats ok I'm bringin a new super too. Looks great.
raul duke is offline   Reply With Quote
Old 01-24-2007, 08:44 AM   #12
Wow Greg, I'm digging on the pinstiping and lettering.
Rockpiledriver is offline   Reply With Quote
Old 01-24-2007, 08:55 AM   #13
R.I.P. Chip
jason's Avatar
I think these things work so well we should ban them.
jason is offline   Reply With Quote
Old 01-24-2007, 11:07 AM   #14
dezfan's Avatar
Pretty slick!
dezfan is offline   Reply With Quote
Old 01-24-2007, 11:40 AM   #15
SVEN's Avatar
In the pics it looks like the shocks don't have the springs in. Are the springs just light to add more droop?
SVEN is offline   Reply With Quote
Old 01-24-2007, 11:51 AM   #16
the springs are inside the shocks. the piston pulls against the spring like a harley softail shock.
Old 01-24-2007, 11:52 AM   #17
The Hustler is designed for 100% droop travel. It works VERY well. There are spings under the pistons in the shocks helping hold the rig down. These springs are included with the chassis kit.
Old 01-24-2007, 12:00 PM   #18
Oops.
That's my fault y'all...
I took my Hustler to the gtg on Sunday & I had my springs in the wrong way...
Sorry Sven. I got 'em fixed now though...
Old 01-24-2007, 12:19 PM   #19
R.I.P. Chip
jason's Avatar
Should I change your user name to Retard?
Old 01-24-2007, 12:34 PM   #20
It's already implied...
I'll try harder.
