08-04-2007, 06:19 PM | #21 |
I wanna be Dave Join Date: Dec 2006 Location: In Cali.
Here is when the Mail man rang the door. Ohh..what ever could it be. THe Mail man is an avid RC guy too. So he knows how important my RC parts are!! Other Hyperion Motor from Holmes Hobbies. He hooked me up with the connectors too! Other Mamba Max..Had to order off someone else John didn't have any in stock.:-( Pile of stuff from JP customs!! Assembly of the CVD's Installation of the CVD's The JP knuckles are awesome. Had to grind a little to make them fit the RC4WD tubes. Knuckles installed. Here are the 17mm adapters I got from RCP. The only thing they lack is the set screws to hold the pin. Rough mock up! Okay...another break. Check out the next post. |
08-04-2007, 06:36 PM | #22 |
The integy stays came with servo mounts. Didn't know that! Jp Customs got me this BTA This mount had to be cut a little to fit the RC4WD axle stays. Before After Servo Mounted up. BTA fully installed. Servo side Motor side Complete axle shot mocked up. Well back to assembly! More pics tomorrow. |
08-04-2007, 06:50 PM | #23 |
Can you show us what the Integy Servo mounts look like mounted up. Just a Mock up would be cool. Thanks ...............Looking good..
08-04-2007, 07:16 PM | #24 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
Any reason you desided to put the motor on the wrong side????
08-04-2007, 07:21 PM | #25 |
RCC Addict Join Date: Jul 2006 Location: barstow
the set screws to hold the drive pins in should have been in the package with the cvd's
08-04-2007, 07:32 PM | #26 |
08-04-2007, 08:03 PM | #27 | |
Yeh, noticed that when I when back to the shop to build the other axle. I almost ran back to the computer and deleted the photo's so you guys wouldn't think I was a noob. This is my first Clod build though! The set screws for the CVD's were there, but the ones for the RCP 17mm wheel adapters didn't have the set screws. They only came with the adapters and the pins. You need set screws to hold the pins in place. I had some laying around, but most people wouldn't! | |
08-04-2007, 11:30 PM | #28 |
After you run your Hustler Run that New Pimp Cane you have sitting there... |
08-05-2007, 01:18 AM | #29 |
Landy mad Join Date: Jun 2005 Location: Newcastle, England, UK
| If there is still clearance to the links would it be a problem? Or would the mesh of the gears be a problem? When I tried to fit my Thundertech BTA Kit with a lathe motor/adjustable mount and Run2jeepn 1" long servo horn I got a foul on the motor. If I used the 3/4" servo horn I couldn't get full steering lock with the CVD's. Is that hyperion shorter than a lathe/adjustable mount assembly? If it is you may not have the problem I did. |
08-05-2007, 09:22 AM | #30 | ||
08-05-2007, 11:42 AM | #31 | |
The link clearance is the main problem, and I don't think you can run as small a pinion with the motor on that side, plus the weight won't be as ballanced. Also you will probably have some problems with clearing that bta kit with the links. | |
08-05-2007, 03:17 PM | #32 |
Okay here are some closeups of the Integy servo holder. |
08-05-2007, 03:19 PM | #33 |
A couple completed axles ready for a Huslter! |
08-05-2007, 03:25 PM | #34 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
I recommend that to take your wallet to the Emergency Room, fast as you can. Very nice build, batteries will be on the knuckles, I assume? |
08-05-2007, 03:35 PM | #35 |
08-05-2007, 05:16 PM | #36 |
Rock Stacker Join Date: Feb 2007 Location: Cincinnati
R4L, I have been looking for a mat like you have in your photos and can't remember who makes them. Any info would be cool. Also, great looking build, i'll be watching it. |
08-06-2007, 08:44 PM | #37 |
08-06-2007, 10:50 PM | #38 |
Pebble Pounder Join Date: May 2007 Location: No Where
nice!!! Wish i had that kind of cash!!!!!
08-07-2007, 12:29 AM | #39 |
What adaptors are those?
08-07-2007, 11:29 AM | #40 |
Newbie Join Date: Jun 2007 Location: Savage Country, SLC UT
| Sweet! Thats really coming together nicely. Can't wait to see it in action.
