07-29-2007, 04:59 PM | #1 |
I wanna be Dave Join Date: Dec 2006 Location: In Cali.
| Building a Super Hustler
Hello all, I purchased a Super Hustler from JIA and I am planning on building it up. Here is a list of things to come. I need a little help with a few things. Since I have never messed with a Clod before. I have a set of stock Clod axles. But I want to beef them up. Front RC4WD Axle Tubes Jp custom knuckles for CVD's Thundertech CVD's Thundertech BTA steering Integy aluminum gear set w/lockers Adjustable Motor spacer Mounts Bearings Rear RC4WD Axle Tubes Jp custom knuckles for CVD's Thundertech CVD's Integy aluminum gear set w/lockers Adjustable Motor spacer Mounts Black Delrin and Aluminum rod ends for Steering links Bearings Other things I have coming for it. Two Mamba Max ESC's BEC Voltage Regulators Hyperion 3013 brushless motors Two JR 8711 servo's 4 Traxxas Big Bore Shocks Spektrum DX6 radio and ESC I need adapters for the CVD's to 23mm. I see that there are several oprions out there, but it seems a bit confusing. What do I need to buy, adapters to 23mm. Keep in mind I am using the CVD's. I am getting Axial Beadlocks with Moab XL's on them. Will these work? http://integy.automated-shops.com/cg...49107604428.00 Thanks Tom Pics will be coming soon!! Last edited by Racer4Life; 07-29-2007 at 10:20 PM. |
07-29-2007, 05:02 PM | #2 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
Arent the axials 17 mm??
07-29-2007, 05:03 PM | #3 |
07-29-2007, 05:03 PM | #4 | |
Rock Crawler Join Date: Jun 2006 Location: Oak Lawn, Illinois
07-29-2007, 05:17 PM | #5 |
RCC Addict Join Date: Mar 2006 Location: Xxx
07-29-2007, 05:36 PM | #6 | |
What Beadlocks will hold up to the Brushless power? I don't really want to drop $250.00 for Aluminum RC4WD beadlocks!! | |
07-29-2007, 05:38 PM | #7 |
07-29-2007, 05:58 PM | #8 |
you can always get the 23mm adaptors and get proline beadlocks, i think these should work on those cvd's, i'll let you know tomorrow when i install the cvd's on one of my clods with the pl beadlocks.
07-29-2007, 09:17 PM | #9 | ||
I used 1/8 scale buggie hexes on my Axials, that and Bender Customs 17mm adapters. | ||
07-29-2007, 09:23 PM | #10 | |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
07-29-2007, 09:29 PM | #11 | |
Thank you sir!! Placing my order shortly!! Thanks for the help on this. I am going to give the Axials a try. If they fail then I get the Pro-Lines. Did you guys narrow the Pro-lines?? | |
07-29-2007, 09:34 PM | #12 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
I've been running the axials since the day I built my hustler, it was the second one made ;) This last weekend I sheared 2 of the pins that hold the adapters to the axles, but I have never spun a hex. |
07-30-2007, 03:11 AM | #13 | |
I wanna be Dave Join Date: Nov 2005 Location: Here
http://www.rccrawler.com/forum/showthread.php?t=75992 Depending on if you want a wider stance or not. I have a set of Bender Adapters that I used once...you could try them. | |
07-30-2007, 08:45 PM | #14 | ||
All parts have been ordered. Just waiting for them to come in. Pics will start rolling soon! | ||
08-01-2007, 09:13 PM | #15 |
Rock Stacker Join Date: Apr 2007 Location: Columbia
| http://integy.automated-shops.com/cg...21107148545.0d check these out, I think that you could use them. |
08-01-2007, 11:15 PM | #16 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
08-01-2007, 11:30 PM | #17 |
I joined the Band! Join Date: Aug 2007 Location: In a rock forest...
I like the sound of this "Hustler" chassis. Where can I get one? Sorry but I am kinda a newb..... I dont know a WHOLE lot about crawling...
08-01-2007, 11:47 PM | #18 |
| www.rcpcrawlers.com Is your hookup!! |
08-02-2007, 04:00 PM | #19 |
Well I now have a few items. I got the RC4WD Axle tubes today. Also recieved the wheel adapters. Should have some more stuff tomorrow!! |
08-04-2007, 06:11 PM | #20 |
Well started to put a few things together. Here are things so far. After a few steps, the door bell rang. Whoooo Hooo. More stuff!! I went ahead and ordered new cases. Since I was pretty much building the axles with all aftermarket parts there was no reason to tear the other apart for the cases! Hyperion Motor JR 8711 servos and Traxxas Big bore shocks! Some of the Integy parts. Close up of the Gears. They are really nice! I had a Traxxas 3.3 bearing kit laying around. It surprised me that most of the bearings are the same size! RC4WD axle tubes. He was kind enough to sell me the tubes seperate. Then he sent me all the knuckles too!! These are really nice pieces. Enough for this post! Check the next post for more! |
