12-06-2007, 09:24 PM | #1 |
Pebble Pounder Join Date: Oct 2007 Location: San Diego
| My Clod hustler build
This is my first Super crawler build. My first crawler build was a AX-10, I'm still making mods to it. I'm using a hustler chassis and clod axles for the super build. There will be what I think is some cool upgrades along the way. But I think I could use some help and some input if your willing to follow along. I will be putting up some pics as well if I can figure it out. how to post them that is.... Parts List: Hustler chassis clod axles thunder tech CVD's proline moab xl 40's Aluminum lockers integy 55T motors x2 HPI shocks (T-MAXX) ????????? The Gooch |
12-07-2007, 06:47 AM | #2 |
12-07-2007, 10:05 AM | #3 |
Thanks for the help and the links. It was easer to become a supporter than mess around with the other options. I hope to have pic's up tonight. I'm trying to up load some pics, but it keeps telling me the file size is to big. I'll try to resize and up load again later. The Gooch Here are the starter pics I said I would post. I'll keep them coning as I get my parts. The Gooch Last edited by Reflection; 01-11-2008 at 09:48 PM. |
12-08-2007, 09:02 PM | #4 |
Rock Crawler Join Date: May 2007 Location: lacey
god i love hustler chassis one of these days, I'm a gonna' pony up and buy one of those. one of these days...
12-08-2007, 10:05 PM | #5 |
Rock Stacker Join Date: Oct 2007 Location: Taranaki
Nice work so far. I have just finished mine. Bloted on a bit of bling for good measure. Had a couple of old 4 cell heli packs not being used so converted them to 2S2P. Now I have 6000mah to play with! Should last all day.... Servos are Hyperion digitals - so far so good. Esc - 2 x Novak Rooster Crawlers (yes twice the glitching but using a BEC certianly helps). BEC Castle 10A. Motors 65T Integy V10 with 8T pinions. The Hustler is a pure pleasure to build with all the various holes lining up perfectly and all parts very high quality. Just 2 little gripes - The Traxxas ball ends are all different lengths with dotts on them to indicate which are which. Not RCP's fault but a note would be nice. Saves having to remove ball ends when the axles turn out crooked. And why oh why do they use a mixture of imperial and metric fasteners? I expect it is because that was what was available at the time, but trying to get 6-32 x 1/4 grub screws outside of the USA is almost impossible! I was short 8 in my kit (actually we got in about 10 kits and they were all short so order spares when you get one). Apart from that it is an excellent crawler! WAAAAAAAYYYYYYY better than my stick. 9.5/10 for RCP. |
12-09-2007, 08:02 PM | #6 |
Nice Hustler man. Thanks for the heads up on the ball ends. I did not know there was a difference, I saw the dots, but did not know. So I took a caliper and did some measurements. They all came out the same +- .10mm. Here are some pics. Also some pics of my Proline Moab 40's and my narrowed Axial Bead Locks.:-P The Gooch |
12-09-2007, 08:21 PM | #7 |
Rock Stacker Join Date: Aug 2006 Location: Albertastan
Hey Toast.......SWEET looking rig. How does it crawl? El Gooch.........did you get all the parts individually or was it the "kit" from RCP? Have fun with the build. Don't forget lots of pics. |
12-09-2007, 08:26 PM | #8 |
All the parts were separate except the links, they came with the Hustler Chassis. I'll be posting lots of pics as soon as I get my Knuckles from JP Custom RC. The Gooch |
12-10-2007, 03:35 AM | #9 |
CHeers Jake. It crawls like a Snail with tennis shoes on a hot summers day in mexico when the sun is high.... Gooch - Its weird about the ball ends. I was told about the dots by a mate so just assembled them in pairs. He recons that they made a difference - who knows. 0.1mm hardley seems worth the effort on Traxxas' part. Thinking I might narrow my rims too. Not sure if its really worth it tho...:? |
12-10-2007, 02:39 PM | #10 |
I just got my JP CustomRC Knuckles in the mail today, YA YA YA YA YA YA YA . Now I can finish the build:-P. I'll be posting up pics as I go. I hope that I have everything now. By the way these knuckles are the coolest I've seen. Nice Job JP Custom. The Gooch |
12-10-2007, 10:24 PM | #11 |
The long awaited knuckles are here. YA YA YA YA :-P
12-10-2007, 10:32 PM | #12 |
Well this is were I am so far. Not sure about the shock position though, could use some help on the setup. I seem to get much more articulation without the shocks. I know that having the shocks mounted will hinder the articulation somewhat, just not this much. Any one have some suggestions for me. The Gooch Getting closer....... |
12-11-2007, 12:13 AM | #13 |
Yep, get longer shocks.... However I recon you wont worry once you have run it over some rocks. It seems some puntas are limiting their articulation to stop rollovers. Sounds good to me. My Hustler will rotate around 50 deg on the front axle with the back on the ground. Works fine. |
12-12-2007, 09:59 PM | #14 | |
Newbie Join Date: Sep 2007 Location: Hot Springs
12-13-2007, 10:16 AM | #15 | |
Jammin57, do you have any photos of your Hustler? Thanks for the input. I was noting that without the shocks I could get about 90deg. front or back, now with the shock it's about 50deg.. One other question, what oil are you using in your shocks? The Gooch | |
12-13-2007, 01:46 PM | #16 |
Newbie Join Date: Sep 2006 Location: Scotland
good looking build you got there!!! could you post a link on what shock mounts you are using? cheers |
12-13-2007, 01:52 PM | #17 |
12-13-2007, 04:18 PM | #18 |
my hustler is not done yet, i just used the oil that came with my shocks to get them together but its not thick enough, i read on here somewhere that people were using thick diff oil for the shocks |
12-13-2007, 05:13 PM | #19 | |
Are you set up for front and rear dig?? The Gooch | |
12-13-2007, 09:38 PM | #20 |
Yea, it will as soon as i get the wireing done and get my dx6 back from horizon, it has 55t integys and dual mamba max esc's, i am just running the stock axle's for now but I am gonna put on some aluminum axle tubes and cvd's and bta steering one of these days, I am new to crawling so I have only built my ax10 and the hustler and its almost done just got to do some wireing and get some battery packs for my JP knuckles.
