11-17-2011, 10:57 PM | #61 |
Quarry Creeper Join Date: Aug 2004 Location: North Las Vegas
Man you are never satisfied are you? I loved the first FJ and now you got me thinking if I could do it......maybe not. What motor and esc are you using?
11-18-2011, 12:46 AM | #62 |
Pebble Pounder Join Date: Oct 2008 Location: Prague, Czech Republic
I like something new. I use combo Novak Crawler Rooster (55t) |
11-18-2011, 08:49 AM | #63 |
Thanks for the info, I was worried my 55 turn venom would be too slow, guess now.
11-18-2011, 12:26 PM | #64 |
YW. I'd made of pure CR-01 crawler. I hope this works. |
11-18-2011, 06:09 PM | #65 |
It's not too bad just wish it had more wheel speed.
11-28-2011, 12:29 AM | #66 |
Little update... I passed the first car. I have to adjust the damper bracket. The rear drive shaft has a little space, so the transmission has a bit to the front due to the addition Dig. To be continued Last edited by carlos46; 11-28-2011 at 12:32 AM. |
11-30-2011, 08:13 AM | #67 |
OK, 4link is ready and the body gets the final form. To be continued |
12-19-2011, 11:07 AM | #68 |
| Re: CR-01 Yota LC40 by carlos46 from CZE
After a short pause, I have a small update ... New Servo 20 kg the protective battery cover and the protective cover of the electronics Today ran a little test. Everything works, but I need the front drive shaft for a little longer. In front of a large cross inaccurately works. and a small video ... První test CR-01 RedBull - YouTube |
01-26-2012, 08:54 AM | #69 |
That looks good! Are those actual red bull cans being used?
01-27-2012, 12:14 AM | #70 |
Yes, this is the cans.
01-27-2012, 12:59 PM | #71 |
Pebble Pounder Join Date: Apr 2010 Location: Calgary
Nice looking rig. Good work on the custom chassis |
01-29-2012, 02:12 AM | #72 |
Last update |
01-30-2012, 05:51 AM | #73 |
Looks great! Defintely has a mean stance to it.
01-30-2012, 11:35 AM | #74 |
Newbie Join Date: Dec 2010 Location: france
Hello Carlos46 ! I haven't been there in a while, been pretty busy the last 3 months Impressive work on the custom chassis, it looks really clean What's with the Bta Setup, did you have difficulties setting it up ? What about the offset that give you the junfac wheels ? wasn't it enought to ensure clearance at full lock ? I looked at your vidéo and saw that you weren't using the Dig on your last set up , is it because of the lenght of your rear drive shaft ? Besides did you use the original links that came with your Cr01 or did you made some longer ones ? I think your rig could benefit from a longer wheelbase ... Did you have a chance to weight your homemade rig with the Rctraxx Dig in it ? Are you making a second version of your chassis, or did you choose to abandon the project and to go back to the Big blue Toyota on your original modified chassis ? Sorry for asking so many questions, had to make up for the lost time Keep up the good work ! Last edited by farfab; 02-04-2012 at 09:22 AM. |
01-31-2012, 12:35 AM | #75 |
Hi, First I must say that the DIG RCTRAX dysfunction. I tried several settings, but always got stuck after a while. Maybe he needs much more space around the correct function, but here I am not in the chassis. second, so I thought instead use the second digital servo for the rear axle as it yours. But I have an older radio, which does not allow me to control fully a third channel. The new I do not have money. Thirdly, the problem with the battery. 1300 mAh on the front axle is too little. I lasted for about 8-10 minutes. Project Redbull I was completely abandoned. The first decks I wanted to do the least due to good function and shock. But it goes wrong. Original Tamiya gearbox is too big. I have in mind an idea for a new chassis, bigger and longer. Inside could fit lipo 2200th Other electronics on the axle. But they still need a better rc transmitter to control the rear axle. Since the CR-01 has poor turning radius. Maybe to go back sometime in the future or buy a XR-10. |
02-04-2012, 09:22 AM | #76 |
hello Carlos46, what you say about the RCtraxx dig confirms what i read about it, it is more a "carpet" disconnect unit than a real one i.e not reliable in harsh conditions. I'm curious about the electronics you are using, because with my setup(35T motor on stock pinions, 2 servos, CC Bec and Rx), i get + 40 mn of runtime on a 1300 mah lipo ... Making the move to a XR10 would surely bring you more rockcrawling performances but the prices are in another category, compared to the modifications you tried on you CR01. Maybe time to invest in a new cheap Tx such as a spectrum. See ya ! Last edited by farfab; 02-05-2012 at 04:28 PM. |
02-05-2012, 04:35 AM | #77 |
I´ve Novak Rooster and original stock motor 27t. Second 55t from Novak combo is a very slowly. |
02-16-2012, 04:47 PM | #78 |
Rock Stacker Join Date: Jan 2012 Location: Houston, Tx and Auburn, AL
your cr-01 crawler "thingy" looks incredible. im jealous of your body painting skill
03-23-2012, 04:20 PM | #79 |
UPDATE soo my little fleet. CR changed the final crawler After the failure of previous custom crawlers fullframe I did not lose because of course it always attracts me. I bought a new body and the car began to build on the original chassis. Actually, I just replaced the original aluminum frame much smaller. Posted by two plastic struts between the two sides took the floor and psh on electronics. Lines are the new longer upper, lower yet original. But I intend to make your own moldings. Dig I threw on my ass and came second servo. I bought a new radio and my friend's all programmed. Now, either my car 2WS or 4WS. For this he once again thank you very much!!! Last edited by carlos46; 09-21-2012 at 01:26 PM. |
03-24-2012, 06:14 AM | #80 |
One of the best crawler conversions I've seen on the CR chassis - great job!
