12-18-2016, 07:56 PM | #1 |
Newbie Join Date: Dec 2016 Location: Under a Bridge
| Axle assembly question
I'm assembling a cr01 and have a question about the axle assembly. The manual say they are tilted at 15deg front and 25 deg rear. How can I determine if I stalled them correctly on the chassis? Thanks in advance. |
12-20-2016, 06:30 AM | #2 |
| Re: Axle assembly question
Build the links and install them in the holes shown in the manual and it should come right...I don't recall any issues when building my 3 kits - just pay careful attention to what goes where. It can get hairy with all those links, holes, and spacers. If you are unsure, post a pic from the side - a picture says 1000 words. |
12-20-2016, 12:23 PM | #3 |
The springs in the front (on the left) seem like they are sort of "bent" and leaning. What do you think? |
12-26-2016, 04:56 AM | #4 |
Newbie Join Date: Oct 2015 Location: Lancaster
There are "15" and "25" markings on the lower part of the hub mouldings which line up with marking on the axle case. Sent from my iPad using Tapatalk |
12-26-2016, 07:44 AM | #5 |
Everything seems spot on to the manual. I know sometimes the springs can get set improperly in the retainers. Try loosening up the retainers and rotating the spring until it seats in a better position.
Axle assembly question - Similar Threads | ||||
aluminum axle assembly? | Jerry3567 | Newbie General | 48 | 08-02-2010 09:26 PM |
axle assembly help | oilylizard | Axial SCX-10 | 6 | 09-22-2009 08:48 PM |
Axle Assembly Conversion | PDXFNG | Venom Creeper | 2 | 04-24-2009 01:06 PM |
Axle upright assembly | Mesozoic | Tamiya CR-01 | 4 | 06-21-2008 01:59 PM |
Axle Re-Assembly Issues | Mad Scientist | Tamiya TLT Crawlers | 5 | 05-28-2007 08:41 PM |
