02-12-2008, 10:50 PM | #1 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
| Badd's HQQD Rat SW3
Bender Customs SW3 chassis (Silver) TLT axles Cases with bearings RCP copper ring and pinion front and rear RCP cvd's front and rear JP Custom knuckles MSD front Axle Cs MSD rear Axle lockouts RC4WD R2D trans... Hitec 645mg (to shift the trans.) Maxx 2.5 driveshafts 45t hand wound motor ( by Badd ) Castel Sidewinder ESC and BEC Hitec 5995mg steering servo 7 cell 2/3A battery packs 1400mah / 1500mah Traxxas shocks Losi white and yellow springs MSD aluminum beadlocks Losi Claws Spektrum radio gear 4 link parts willbe a mix of Traxxas REVO/JATO links & bend rear lowers Losi Grappler Body (Paint by Badd) I just now got time to do a build thread on this one . I want to say thanks to Bender, Tanis & Unimoger Last edited by Badd; 11-04-2008 at 06:27 AM. |
02-12-2008, 10:56 PM | #2 |
moving forward about 2 weeks it is now a roller . In this pic you can see the stock SW3 skid . in this pic you can see how I inboarded the links . I also did a little mod to my servo/top link mount seen here upper link mount mod Last edited by Badd; 02-14-2008 at 07:35 PM. |
02-12-2008, 11:00 PM | #3 |
here is a few pics of it as a roller and the flex shot |
02-12-2008, 11:01 PM | #4 |
and the body |
02-12-2008, 11:04 PM | #5 |
and all together |
02-12-2008, 11:10 PM | #6 |
upgrades started today the steering as it was the 5995 love the tlt rodends . so I used a revo rod with 1 Revo rodend and 1 Jato to made my lower link and I use some 4mm althread and revo ends to make the top . oh and the turning is not BADD I also changed out the springs . I put the Losi Yellows on the front and Traxxas Reds on the rear. the angle that I have the shocks the White/Yellow front / rear comb was to soft . I also replace the oil in the rear shocks with 30 weight .
02-12-2008, 11:42 PM | #7 |
Rock Crawler Join Date: Sep 2004 Location: South Orange County
looks great
02-12-2008, 11:42 PM | #8 |
I was running a 10 pinion gear with the hand wound 45turn . but I got to make a trip to get a 11 and 12 tooth . I also redid the motor it is now a 35 turn . the R2D is geared really low with the stock 8 tooth . the power with the 45turn and 10 tooth was unreal but wheel speed was a little slower than I like .
02-13-2008, 05:53 AM | #9 |
Nice looking SW3, mine rig is almost the same set up and equipment only differance is I'm running the Novak Goat system. |
02-13-2008, 08:25 AM | #10 |
Rock Crawler Join Date: Nov 2005 Location: dallas
Nice paint on the losi lid |
02-13-2008, 03:01 PM | #11 |
I used the write up by rkrawler to do the 3 position toggle switch mod on my DX3 . DX3 toggle switch installation here is one of his pics from the write up . |
02-13-2008, 03:08 PM | #12 |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
Very nice work All the parts to make a good strong rig.... |
02-13-2008, 06:08 PM | #13 |
The 3 is looking good Badd, and thanks for the link for altering the switch, my buddy is going to be stoked to see it can be done |
02-13-2008, 10:26 PM | #14 |
02-14-2008, 06:45 AM | #15 |
Rock Crawler Join Date: Jan 2006 Location: Tennessee
Badd- how do you like those tires for around here? |
02-14-2008, 08:16 AM | #16 |
| they are a great tire , big stepup over Moabs . they pull verts better , sidehill alittle better , cleanout alittle better . I started running them in July of last year . The only tire that might work as good or better wouldbe the new pro-line Badlands .
02-14-2008, 08:25 AM | #17 | |
they look awesome for trail riding the spots here at the golf course | |
02-14-2008, 08:32 AM | #18 |
| I like masher 2ks myself . If you are running in Mud and Roots (not comps) I would say Mashers might have a edge . Just because they clean out better . Thanks for the good words on The HQQD Rat. |
02-14-2008, 07:25 PM | #19 |
Quarry Creeper Join Date: May 2006 Location: Snake Run, IN
Love the paint Badd!
02-14-2008, 08:02 PM | #20 |
I done some testing today . I ended up changing the foams . I have had good luck with stock Axial foams in Losi Claws . I narrowed them about 3/16" and put the cut side of the foams to the inside of the tire . I also ended up adding 3 oz to the rig . that was 1 1/2 to each axle . more testing this next week but all and all it is working good . Edit : I forgot to say ran the 8 tooth pinion to get the rig up and running . I changed it to a 10 tooth biggest 32 pitch I had but it was still on the slow side . So today I changed it to a 12 tooth . It brought it alive with the 35 turn hand wound . There is plenty of power and wheel speed .
