Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: Widener Comparison Chart
Old 02-08-2007, 05:46 PM   #61
I offer the MSD ultimate wideners that you can use with the blackfoot stubs or the AE stubbs too. Very affordable!
www.montanascaledesigns.com
Unimoger is offline   Reply With Quote
Old 02-10-2007, 06:47 AM   #62
I put bearings in the axles, so i used the brass bushings as spacers..just had to thin them down a little.
I got three axles drilled out to accept the hex pins, but the third one ate my bit! Ended up filing a panelling nail to fit.
If anyone uses the ASSociated 3/16" axles, make new hex pins and save yourself the trouble of drilling into that hardened axle stuib!
mascman is offline   Reply With Quote
Old 03-01-2007, 09:03 AM   #63
Originally Posted by gopher
question tho... the chart says 12mm-30mm even bigger i've noticed tobee has (40 or 48mm?!)
anyhow... is that overall length? or just one side?
so would a set of 12mm increase 12mm overall, or 24mm? my assumption is 12mm
So......Whats the answer? Anyone, Bueler???
metomwhou is offline   Reply With Quote
Old 03-05-2007, 03:47 PM   #64
Im Brandon
Brandon's Avatar
12mm will widen you 12mm overall, approx 1/2"
Brandon is offline   Reply With Quote
Old 03-08-2007, 12:36 AM   #65
What are some wideners people use, or spacers, or washers. I am using the black foot stub shafts... Thanks!
5150bronco is offline   Reply With Quote
Old 03-08-2007, 09:23 AM   #66
Im Brandon
Brandon's Avatar
Looks about 5 posts up
Old 03-20-2007, 11:54 AM   #67
See pics below:
PaloAltoK5 is offline   Reply With Quote
Old 03-21-2007, 07:56 PM   #68
Thanks Art, yea, I remember you telling me that last time....Good stuff...
I am putting those shafts on tonight.....I love em.
Old 03-22-2007, 05:55 PM   #69
ok so heres the scoop...
i have been dreaming about this forever and now i know how to get one the problem with buying one now is that i dont even have a real body all i have is a nylint 1:6 scale from walmart wich are going for a lot of cash online now but i would never part from her anyways real scale offroaders cost alot and im young and got fired from my job (Hobby Town Usa) about a week ago because they said they were getting asked too many ?s about my age being that im only 14 and had a permit to work there its bull**** but they said it was bad for buisness so i cant buy one cuz im broke i need soem help on exactly what i need to build a good rccrawler i need to know exactly what i need to be able to shop around and get a total so i can save please help please i want to get deep into this whole rock crawling scale style thing - Blubbersnap
____
|__|
blubbersnap is offline   Reply With Quote
Old 04-03-2007, 10:15 AM   #70
Wink
i have the inet ones on my and they work great
joen007 is offline   Reply With Quote
Old 04-04-2007, 06:38 PM   #71
Originally Posted by PaloAltoK5 View Post
See pics below:
So Art, I finished putting the blackfoots on....they look cool and a bit wider....
I just went to orchard and bought some nylon spacers for the wheel spacers/wideners and they worked out great...
thanks for the advice and here is an update...
Missed you at the comp too.....
later.
Old 05-18-2007, 08:37 PM   #72
Location: Taylors Falls just hanging with the MNRCRC crew.
Default Everything in moderation
I think I'll go for a little wide to start with.
Stormin2u is offline   Reply With Quote
Old 05-18-2007, 10:34 PM   #73
sooo........ not to be a jerk but this picture really souldn't be used for reference other than seeing what the wideners look like, because the pivots aren't lined up and since some of the shots look like they were shot with a horribly fish-eye lens so the perspectives are all different.......... (my lines are drawn vertically from the bottom axle)
moonbuggy is offline   Reply With Quote
Old 06-29-2007, 02:31 PM   #74
I just ordered some Gmade wideners for my Hummer, I'll post a pic when I get them.
Stallion1967 is offline   Reply With Quote
Old 10-22-2007, 04:50 AM   #75
is this a good thing to go for?
http://cgi.ebay.com/43240-Tobee-Craf...QQcmdZViewItem
and this
http://cgi.ebay.com/43640-Tobee-Craf...QQcmdZViewItem
infernox is offline   Reply With Quote
Old 10-23-2007, 09:18 AM   #76
Originally Posted by infernox View Post
Too wide and don't know about the second one...looks too short and pricey....usually use some Traxxas links or make your own. If you don't want to make your own links buy one of the chassis with links from a vendor on this bb....there are several to chose from that are very nice.
Old 10-24-2007, 12:29 AM   #77
cool thanx, does the copper bushings not promote slip?
Old 01-11-2008, 03:52 PM   #78
So who else out there makes the INET style of widener since inet has discontinued them?
crash is offline   Reply With Quote
Old 04-20-2008, 10:40 PM   #79
ok so for the newbie out there can you guys let me know what the benefits of widening does? and can it be done on a tlt with the normal axles or do I need to upgrade those aswell?
Samurai is offline   Reply With Quote
Old 07-15-2008, 11:22 PM   #80
Being wider helped my rig on side hills.....
Being wider also cut back on some passages and they way you attack them...
I like the front about a 1/4 inch wider then the rear....
hessian18 is offline   Reply With Quote
