Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: Badd's HQQD Rat
Old 02-12-2008, 10:50 PM   #1
Default Badd's HQQD Rat SW3
Bender Customs SW3 chassis (Silver)
TLT axles Cases with bearings
RCP copper ring and pinion front and rear
RCP cvd's front and rear
JP Custom knuckles MSD front Axle Cs MSD rear Axle lockouts
RC4WD R2D trans... Hitec 645mg (to shift the trans.)
Maxx 2.5 driveshafts
45t hand wound motor ( by Badd )
Castel Sidewinder ESC and BEC
Hitec 5995mg steering servo
7 cell 2/3A battery packs 1400mah / 1500mah
Traxxas shocks Losi white and yellow springs
MSD aluminum beadlocks
Losi Claws
Spektrum radio gear
4 link parts willbe a mix of Traxxas REVO/JATO links & bend rear lowers
Losi Grappler Body (Paint by Badd) I just now got time to do a build thread on this one . I want to say thanks to Bender, Tanis & Unimoger
Badd is offline   Reply With Quote
Old 02-12-2008, 10:56 PM   #2
moving forward about 2 weeks it is now a roller . In this pic you can see the stock SW3 skid . in this pic you can see how I inboarded the links . I also did a little mod to my servo/top link mount seen here upper link mount mod
Old 02-12-2008, 11:00 PM   #3
here is a few pics of it as a roller and the flex shot
Old 02-12-2008, 11:01 PM   #4
and the body
Old 02-12-2008, 11:04 PM   #5
and all together
Old 02-12-2008, 11:10 PM   #6
upgrades started today the steering as it was the 5995 love the tlt rodends . so I used a revo rod with 1 Revo rodend and 1 Jato to made my lower link and I use some 4mm althread and revo ends to make the top . oh and the turning is not BADD I also changed out the springs . I put the Losi Yellows on the front and Traxxas Reds on the rear. the angle that I have the shocks the White/Yellow front / rear comb was to soft . I also replace the oil in the rear shocks with 30 weight .
Old 02-12-2008, 11:42 PM   #7
looks great
iwantoffroad is offline   Reply With Quote
Old 02-12-2008, 11:42 PM   #8
I was running a 10 pinion gear with the hand wound 45turn . but I got to make a trip to get a 11 and 12 tooth . I also redid the motor it is now a 35 turn . the R2D is geared really low with the stock 8 tooth . the power with the 45turn and 10 tooth was unreal but wheel speed was a little slower than I like .
Old 02-13-2008, 05:53 AM   #9
Location: Taylors Falls just hanging with the MNRCRC crew.
Nice looking SW3, mine rig is almost the same set up and equipment only differance is I'm running the Novak Goat system.
Stormin2u is offline   Reply With Quote
Old 02-13-2008, 08:25 AM   #10
miniwheeler's Avatar
Nice paint on the losi lid
miniwheeler is offline   Reply With Quote
Old 02-13-2008, 03:01 PM   #11
I used the write up by rkrawler to do the 3 position toggle switch mod on my DX3 . DX3 toggle switch installation here is one of his pics from the write up .
Old 02-13-2008, 03:08 PM   #12
Very nice work
All the parts to make a good strong rig....
crash is offline   Reply With Quote
Old 02-13-2008, 06:08 PM   #13
Keep it real
Tanis's Avatar
The 3 is looking good Badd, and thanks for the link for altering the switch, my buddy is going to be stoked to see it can be done
Tanis is offline   Reply With Quote
Old 02-13-2008, 10:26 PM   #14
the mod is easy and if you leave the new switch in the center , the stock switch will still work the same .
Old 02-14-2008, 06:45 AM   #15
rbl
rbl's Avatar
Badd-
how do you like those tires for around here?
rbl is offline   Reply With Quote
Old 02-14-2008, 08:16 AM   #16
Originally Posted by rbl View Post
Badd-
they are a great tire , big stepup over Moabs . they pull verts better , sidehill alittle better , cleanout alittle better . I started running them in July of last year . The only tire that might work as good or better wouldbe the new pro-line Badlands .
Old 02-14-2008, 08:25 AM   #17
rbl
rbl's Avatar
not to get off topic on the hQQd rat cause it looks awesome, but i always loved my 2.2 mashers with a groove cut in them.. but ill have to try some...
they look awesome for trail riding the spots here at the golf course
Old 02-14-2008, 08:32 AM   #18
I like masher 2ks myself . If you are running in Mud and Roots (not comps) I would say Mashers might have a edge . Just because they clean out better . Thanks for the good words on The HQQD Rat.
Old 02-14-2008, 07:25 PM   #19
pup
Love the paint Badd!
pup is offline   Reply With Quote
Old 02-14-2008, 08:02 PM   #20
I done some testing today . I ended up changing the foams . I have had good luck with stock Axial foams in Losi Claws . I narrowed them about 3/16" and put the cut side of the foams to the inside of the tire . I also ended up adding 3 oz to the rig . that was 1 1/2 to each axle . more testing this next week but all and all it is working good . Edit : I forgot to say ran the 8 tooth pinion to get the rig up and running . I changed it to a 10 tooth biggest 32 pitch I had but it was still on the slow side . So today I changed it to a 12 tooth . It brought it alive with the 35 turn hand wound . There is plenty of power and wheel speed .
