06-11-2006, 09:18 PM | #101 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
They are just the long 2.5 half shafts. Buy 4 of the yokes I listed and a package of these. http://www2.towerhobbies.com/cgi-bin...?&I=LXSP55&P=Z |
06-12-2006, 01:09 AM | #102 | |
Pebble Pounder Join Date: Jan 2005 Location: Idaho
12-12-2006, 07:26 AM | #103 |
Quarry Creeper Join Date: Dec 2006 Location: Finland
Nice crawler. Btw what's name of this body and can you get it from tower hobbies? http://www.rccrawler.com/forum/attac...1&d=1123998701 |
12-12-2006, 08:35 AM | #104 | |
I'm not sure who made the body, I bought it a long time ago. I just checked Tower and didn't see it listed. | |
04-25-2007, 08:17 PM | #106 | |
Newbie Join Date: Mar 2007 Location: Augusta
Could I get a little help on the driveshafts. I bought part number 1951 and 4628x, is this the best way to go? I also purchase part number 4951, I know I need to take some of these back, what is the optimal driveshaft set up? If I go with part number 4628x and the 1951's what modifications do I need to make? Thanks Travis | |
04-25-2007, 11:00 PM | #107 | |
04-26-2007, 11:02 AM | #108 |
The parts that I have are apparantly for the stampede, will they work, are they strong enough? Thanks Travis |
04-26-2007, 11:08 AM | #109 |
Another question, if I do need to go with the 4927x do they make that in steel? Or, if I go with the ones that I have, which have 2 grub screws will I need to modify the pinion? Thanks Travis |
04-26-2007, 11:58 AM | #110 | |
They don't make the Maxx yokes in a steel version. The plastic yokes are plenty strong enough. I've broke inner axles and ring/pinion gears with the Maxx shafts, they don't really have any signs or wear aside from rock rash. I've personally never used Stampede driveshafts, so I'm not sure how the 2 grub screws will work. I did drilled my axle's pinion shafts out for the Maxx yokes and screw pins. | |
04-26-2007, 12:07 PM | #111 |
I use pede's on mine, w/ the metal yokes the grub screws hold great on the pinion if you locktite them. |
04-26-2007, 02:32 PM | #112 |
04-26-2007, 02:45 PM | #113 |
| Yes, I do just that for the pinions, I use a Pede tranny so no need there. I have been running them forever, I have only popped 2 off and it was while using lots of brushless wheelspeed running Mashers, never has happened running Moabs.
04-26-2007, 05:54 PM | #114 |
I really appreciate all the help. Does anyone have a picture of how the center links mount to the axle, as welll as to the chasiss?
