06-23-2005, 11:09 PM | #1 |
| Widener Comparison Chart
I hope you guys find this usefull. When I was first looking for wideners I wish I had something like this for referance I used photoshop to line up all the axles and make them all the same size so its pretty accurate. If you have other wideners on your TLT axles please send me a pics similar to those above and I can add to it!! Thanks! Brandon EDIT: Posted this in the sticky TECH thread, but I would like to keep this one also for any comments. Last edited by Brandon; 06-23-2005 at 11:16 PM. |
06-24-2005, 12:01 AM | #2 |
Pebble Pounder Join Date: Apr 2005 Location: Torrance, CA
That's pretty good. You want me to get you a pic of my Blackfoot stub axle equipped axle?
06-24-2005, 12:04 AM | #3 |
06-24-2005, 01:07 AM | #4 |
RCC Addict Join Date: Feb 2005 Location: Crawlifornia Uber Alles
the axle with the inet wideners- what are those braces by the ends? looks very interesting! |
06-24-2005, 01:17 AM | #5 | |
06-24-2005, 02:02 AM | #6 |
Rock Stacker Join Date: May 2005 Location: Las Vegas
Inet isn't planning on making their wideners for quite some time, I guess they're really low on their priority list. I ended up purchasing a set of the Tobee Craft 32mm ones off ebay, should be getting them soon. If interested, I'll snap a photo once I get them on. |
06-24-2005, 04:29 AM | #7 | |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
those are axle braces.. i forget who makes them | |
06-24-2005, 07:44 AM | #8 | ||
06-24-2005, 06:03 PM | #9 |
Blackfoot axles added. Thanks Frito! Looks like they are just shy of the 16mm tobee craft's but the threads are much longer which would be great for the stampede wheels. Thanks again. |
06-24-2005, 06:43 PM | #10 |
I don't think the Blackfoot threads are any wider than stock. They just look that way because I didn't have the hexes on there. I have my three piece wheels so I only use the pins and didn't think to put the hexes on for the pic. :(
06-25-2005, 11:20 AM | #11 |
Hmm ya it probably just looked that way bc there are no hexes like you said. Has anybody tried the wideners by Gmade?? Check them out http://gmade.net/skin/gmade/goods/pr...e=030000012286 |
06-25-2005, 11:28 AM | #12 |
Newbie Join Date: Jun 2005 Location: East Kilbride (just outside glasgow)
How wide does that make your tlt, at the moment mine is 10 inches wide but i would like to get some extra
06-25-2005, 11:37 AM | #13 |
Well the tobee crafts widen the truck by 16mm & 24mm as pictured. So 10 inchs plus that, if you go with the inets it will be even more, probably around 11 1/4"
07-06-2005, 10:27 PM | #14 |
Just added the tobee craft 32mm wideners! Thanks Joe Mauma
07-07-2005, 03:32 AM | #15 |
Rock Stacker Join Date: Sep 2004 Location: on Earth
| how about this? G-made 2.2" widnwner is open.. |
07-07-2005, 07:35 AM | #16 |
I almost bought a set of those, has anybody tried them?? They are cheaper than the inet ones, $27 I think...
07-07-2005, 07:43 AM | #17 | |
| i..used Quote:
i fill up satisfaction... but one modify,,, 5mm With it widens the hole of the wheel and must give. | |
07-07-2005, 08:30 AM | #18 |
Hmm I thought it was only 1" wider total, not each side. But I may be wrong. And I think that if you have 2.2" tires and wheels you might not have to make the whole bigger. Somebody needs to try them!!
07-07-2005, 10:08 AM | #19 | |
| oh...you miss one thing,, Quote:
i have 2.2" tire and wheels.. i used All-T 2,2" & ofna pirate wheels... this widner is new fixed bolt.. This bolt diameter is 5mm.. TLT normal axle shaft is only 4mm.. do you understand?,, if not sure ..... and question me.. um.. i have a mistake.. 1" widen than normal,....not 2" have a nice. day,, Last edited by bobnom; 07-08-2005 at 12:02 PM. | |
07-07-2005, 08:54 PM | #20 |
Rock Crawler Join Date: May 2005 Location: Fort Wayne
Im pretty the axle braces are PRP.
