Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: Project "Cletus" is here....
Old 11-01-2004, 09:14 PM   #21
Default Re: "Cletus" is coming soon.....
Axles: TLT locked up with MTPA Lock-Snot
Tranny: Stampede with 2.5 Maxx sliders
Motor: Integy Lathe OR Magnetic Mayhem... or that 9-turn
Chassis: Old Clod chassis re-born
Body: AE Toyota Baja
Steering: Hitec HS605BB
ESC: Super Rooster
Winch: Hitec HS-5645MG
.... and other little things
Gotta get my bits in.......
toyofast is offline   Reply With Quote
Old 11-01-2004, 09:25 PM   #22
Not trying to kiss your ass here or anything, but seeing that youre one of the top guys in crawling, Do you mind posting some pics and a possible mini writeup of how you did the maxx driveshaft conversion on the tranny and axles?
Jim511 is offline   Reply With Quote
Old 11-01-2004, 09:29 PM   #23
I know you are a Toy guy at heart but body is just hideous, and the orange paint makes it even worse
BARK is offline   Reply With Quote
Old 11-01-2004, 09:53 PM   #24
I think it looks fine, and I like the orange paint!
Nice crawler toyo, can't wait to see some action pics of it... once u get ur shocks mounted up and everyting lets see it run!
KidWithAcrayon is offline   Reply With Quote
Old 11-01-2004, 10:24 PM   #25
bwahahahahahahahahaha You mean those two old things I've got out back have a use?!?!
SR5Dave is offline   Reply With Quote
Old 11-01-2004, 10:48 PM   #26
Looks good, just put a tube bumper up front, that over sized chrome monstrosity never came on a toyota!
TOYOTA PRIDE BABY!
Plays_with_Toys is offline   Reply With Quote
Old 11-01-2004, 11:00 PM   #27
The Maxx sliders just about bolt-on to the 'Pede tranny outputs. Just have to trim the bearing case of the tranny a bit and shave down the slider end to allow the pin to go through without having the sliders bind with the tranny bearing case.
REVO sliders would take the same amount of work as Maxx ones but the REVO's would just be overkill.
On the axles you just have to make two grub screws and lock it into place as best as you can. Add some CA or JB-Weld to make it really stay
Old 11-01-2004, 11:02 PM   #28
rbgerrish's Avatar
Just paint the bumper black and you're good! I love the body! You should have painted it Olive Drab though...
ryan
rbgerrish is offline   Reply With Quote
Old 11-01-2004, 11:04 PM   #29
A tube bumper never came on a Toyota either.....
The bumper still needs work.... I plan to narrow it and drop it about 1/2" or so just to get it below the grill/headlights. I would go with another bumper but the stock Clod one is VERY stout and being able to bolt it right to the chassis is great. Super solid.
This whole truck is far from being finished.... bumpers, rest of suspension(links & shocks), radio gear and so on...
Old 11-01-2004, 11:06 PM   #30
Lookin good Toyo, I like the stock clod chassie idea
BTW I used revo shafts by drilling a hole in the output yoke on the axle, if you use the revo yokes you would also need to trim around 1/8" off the back for them to fit right aswell. It's not a hard conversion-just takes a bit of work.
Highmark is offline   Reply With Quote
Old 11-02-2004, 09:59 AM   #31
Oh but, they did:
Old 11-03-2004, 07:04 PM   #32
hey toyo you have a pm or a couple
bigred is offline   Reply With Quote
Old 11-07-2004, 01:33 PM   #33
Got the little rig running this morning... still many bugs to work out but so far so good.
Need to lower the ride height, stiffen up the suspension and trim the body.
Old 11-07-2004, 01:44 PM   #34
Default Re: Project "Cletus" is here....
That looks really cool. Why didnt you paint the spare tire.
xtman is offline   Reply With Quote
Old 11-07-2004, 04:14 PM   #35
I'm going to be cutting out the molded in spare tire to fit a real spare tire into it's spot. Plus I think I'll be cutting out more of the bed area. The spare tire is a stock TLT tire/wheel cut down to 1" wide.
The truck still has plenty of bugs to work out and things to be finished before it's done... but I just had to take it for a test run
Old 11-07-2004, 04:53 PM   #36
yo toyo iyt just donned on me what paint job that is its the ultimate toca(tocoma) from petersons offraod thats cool do i win a prize for that
Old 11-07-2004, 05:54 PM   #37
Ran another pack through the little rig..... then carnage happened
Had to back up just a bit to give it more gas to get up and over the rock... went a bit fast...
Jumped over the rock and as it hit I heard a pop... the rig then proceded onto it's side.
Upon inspection I noticed that I snaped off the rear yoke.
Then decided to play around with only front wheel drive... 'twas a hoot!
...untill the front yoke popped off the pinion
This thing has way too much power for it's weight. Only weighs 3lbs :P
Old 11-07-2004, 07:11 PM   #38
i think you need steel yokes to fix your probleam
austinsclod is offline   Reply With Quote
Old 11-07-2004, 07:13 PM   #39
Did you have that axle super glued on? If not, whay is it and the pinion and axle all white?
mtdriver is offline   Reply With Quote
Old 11-07-2004, 08:06 PM   #40
Do they make steel yokes for the Maxx sliders? If they do, I never knew. I know they have them for the 'Pede sliders.
Yeah, I added a bit of CA to help hold them on.... and I guess it didn't help too much
