03-22-2006, 11:25 AM | #21 |
If you want to take it any farther, you should try a smaller battery pack. IB 1200's or 1400's would be perfect. Beyond that a new chassis is about the only direction you can take it.
03-22-2006, 11:33 AM | #22 |
Yep, a lighter battery will do wonders for your CG. Look into a HobbyZone Firebird Commander airplane battery, theyre 900 mAH, and about $19 at your LHS, but you'll have to change the plug. It's small enough to mount on the upper links, too. Looks like a shrink-wrapped six-pack. www.hobbyzonesports.com if you want to shop online. Another thing that will really help is a set of axle wideners. Not only does it help stability, but it help keep the tires from rubbing the links at full lock. |
03-25-2006, 07:45 PM | #23 |
Pebble Pounder Join Date: Jan 2006 Location: Canada
Now that I've got this one pretty much done, I'm tinkering on another build using a Losi XXX tranny. Pretty similar configuration with the drive cups. One little tidbit I discovered tonight is that if you heat the hardened outdrives with a propane torch until they start to turn red, it makes them very easy to drill. The heat takes the temper out of the steel, but they are hardened to prevent wear from the dogbones, and if you're mounting sliders the hardness is not required.
05-09-2006, 08:30 AM | #24 |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
nice job......got any details on how you mounted the drive shafts to the stealt tranny? |
05-10-2006, 08:09 AM | #25 |
The details are in the first page of this thread. I didn't snap any pics, but it really was quite simple. One tip though, these outdrives are extremely hard steel. It is a lot easier to cut and drill them if you take some of the temper out of them by first heating them with a propane torch until they start to turn orange then let them cool slowly.
05-19-2006, 10:15 AM | #26 |
RCC Addict Join Date: May 2006 Location: Roseville
Your build is inspiring. I have been thinking about putting together a crawler using the stock chassis and I think your build is the ticket. What are your lower links? They look store bought, not made. What length are they etc. I wish you had more pics of the modified tranny, my brain is having trouble visualizing how you made everything work.
05-19-2006, 06:11 PM | #27 |
The lower links are Revo push rods shortened an inch or so. I originally built it to have a wheelbase of about 12.5", but have since shortened it to a little over 11.5" to give a more scale fit on my Early Bronco body.
05-19-2006, 11:59 PM | #28 |
Pebble Pounder Join Date: Mar 2006 Location: Milan, IL QCA (rural)
I have a TLT and a Stealth trans here... are you saying the drive yokes for your shafts are big enough to go OVER the Stealth dog bone cup outdrives? I have never had my hands on anything but the Stampede sliders and they are not near big enough to go over the stock stealth cups. Another brain block I am having is how to lock a ball diff, the Stampede has a gear diff and that is much easier to figure out how to lock.
05-20-2006, 07:37 AM | #29 | |
yes they fit over..........once you drill them out. I have it in my TLT.......also to lock is simple remove the balls and add a lil CA and retighten locked forever. no brainer | |
05-20-2006, 08:41 AM | #30 |
I used T-Maxx yokes on mine. The Stealth outdrives easily fit inside the drilled out yokes. I also shortened the outdrives by aobut 1/4" so that I could make the driveshafts as long as possible and make for a cleaner install. I don't know if all versions of the Stealth use the same diameter outdrives, but on the B4/T4 version that I used, the outdrives have a diameter significantly smaller than the Losi XXX tranny. |
05-20-2006, 09:26 AM | #31 |
I wanna be Dave Join Date: Nov 2005 Location: Crawler practice!
it almoast looks like a bender sw2 if it had more curvs and a lay down tranny clean build though i might take ur idea if my scaler dont work out
06-14-2006, 10:46 PM | #32 |
Pebble Pounder Join Date: Aug 2005 Location: San Francisco
Excellent work. The insturctions werent to clear on how to intall maxx shafts to the stealth. Can you still load some detailed pictures and detailed instructions.
06-15-2006, 12:15 AM | #33 |
Quarry Creeper Join Date: Nov 2005 Location: Louisville, KY
Did you modify the chassis any besides drilling more holes and making the slot in the side bigger? It looks like you cut some off of the bottom too. If you did how much did you cut? Only bad thing about a box stock tlt, the chassis hangs way too low.
06-15-2006, 12:26 AM | #34 |
Ya he cut off a little over an inch off the bottom. See where he has his lower links mounted. Those are factory holes. I just got done doing this to mine aswell.
06-15-2006, 01:05 AM | #35 |
Good. I was planning on buying a chassis when I get mine because I thought the stock one was crap but then I seen what this guys done and i'm going to try this first. Sounds like the same thing I did on my Nylint before I filled the front axle with mud and it quit working.
06-15-2006, 05:13 AM | #36 |
very nice set up, hopefully i will be able to do more or less the same mods to my penguin chassis |
06-16-2006, 06:58 PM | #37 | ||
06-17-2006, 02:10 AM | #38 |
I cant seem to find the revo yoke that goes on the axle. Can you give me part numbers. Thanks and sorry for the noob question
06-17-2006, 05:42 PM | #39 | |
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXMJG9 Traxxas part #5458X I used these because that's what I had. The standard T-Maxx yokes would work as well. | |
06-17-2006, 10:33 PM | #40 |
Newbie Join Date: Jun 2006 Location: New York
do you have a part number on the t-maxx shafts that you connect to the yokes? looking to do this with a Losi XXX tranny that i got laying around
