05-28-2006, 11:16 PM | #21 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
That looks absolutely awesome man-should work very well. |
05-29-2006, 09:20 PM | #22 |
Rock Crawler Join Date: Jan 2005 Location: Tumwater
I just bit the bullet and made the brushless order. Kevins rear motor had so much torque for the weight I just could not resist. If the combo comes before sunday I will be running lighter than a t4 stadium truck.
05-29-2006, 09:51 PM | #23 |
Here is a side shot of the latest chassis with the electronics up front centered side to side. The pivots are on the back fiberglass piece, and 3 inches under the tranny. I love how low the big lipo is and the bta looks like it will work as well as before.
05-29-2006, 11:24 PM | #24 |
A shot of the electronics plate, and one next to the t4 showing the linkless chassis flexing a'bit.
05-30-2006, 06:37 AM | #25 |
Grover, you're making my brain hurt. I wouldn't be surprised if you managed to make one out of thin air I'm impressed. Any damping issues with the lack of shocks on the thing? |
05-30-2006, 08:13 AM | #26 | |
05-30-2006, 08:22 AM | #27 |
Quarry Creeper Join Date: Sep 2005 Location: Lufkin
I'm not sure I understand how this thing works. Is the plate/pan twisting and that is where you get the articulation from? Or are there actual pivot points that I'm just not seeing?
05-30-2006, 10:27 AM | #28 | |
In post number 23 you can see the team associated pivots on the pan chassis both behind the tranny and centered. The last version with the alloy backbone and fiberglass plates you can see one adjuster/pivot sticking up out of the body just above the rear axle. There are two more on that same plate that I do not adjust. The backbone does give alittle(only in the desired directions) but not enough on this light of a truck to not use pivots. | |
05-30-2006, 11:30 AM | #29 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
I don't think I'm seeing how it flexes either. From the pix it just looks like the chassis twists. I don't see anything on the top of the chassis that looks like it would pivot.
05-31-2006, 06:23 PM | #30 | |
06-01-2006, 04:01 PM | #31 |
lexan belly went on today.
06-01-2006, 06:01 PM | #32 |
Rock Stacker Join Date: Nov 2005 Location: Northfield
crazy it's so simple yet there is so much detail and work put into it grover thats a tight rig |
06-02-2006, 04:17 PM | #33 | |
06-02-2006, 04:21 PM | #34 |
And welcome to the Revolution |
06-02-2006, 04:31 PM | #35 |
Why thank you Microgoat. This higher tranny postition would have been a huge compromise (compared to the original grover tlt setup) with standard electronics. It seems like I have kept the cg about the same and gained over a half an inch in breakover with this design. With no rear steer I know that I am asking alot of this truck to hold my 2.2 lead with two rounds to go. I need to start driving front steer only to prepare for those boys in Oregon...not just that, NO ONE to my knowledge has ever won a PARC 2.2 event with no rear steer(so there is something to shot for). |
06-02-2006, 04:35 PM | #36 | |
WOW, that truck is awesome Grover, soo far outside the box, I love it, great ideas and engineering. Can't wait to see the NEW video of it crawling. | |
06-02-2006, 11:51 PM | #37 |
Rock Crawler Join Date: Nov 2005 Location: dallas
I will be looking for youre crawler at the next comp I really want to check out youre chassis and that BL setup and see how it works, it might be time to join the revolution |
06-04-2006, 12:06 AM | #38 | |
06-04-2006, 12:39 AM | #39 | ||
The Goldendale event won't be a actual ORCRC based comp. More or less a for fun type comp. All the ORCRC comps are already set into the calander. Quote:
06-05-2006, 10:26 AM | #40 |
No first place this time. I stripped three spur gears...the truck still made it through all stages and toulk second overal. The modded gear box needs to be replaced with a new stiff case or the stealth Kevin has on the test bench. I was over the moon with the performance of the new electronics, and the chassis performed as expected |
