06-05-2006, 10:30 AM | #41 |
Did you run the Revolver and Mamba? LOTS of power! |
06-05-2006, 12:38 PM | #42 |
Rock Crawler Join Date: Jan 2005 Location: Tumwater
| Loving the quark!
Dezfan I was running the quark33 revolver. I love how much quieter the quark33 is than the mamba and the bec did a great job running my 645 under heavy load. The brushless set up was flexing the gear case so much you could actually see it move so this morning I went to the lhs and picked up a fresh(untrimmed) stampede case to see if that solves the issue. It is amazing that I ran the modded case with a 55turn lathe and 11.1lipo since before christmas with out a single issue and this brushless set up is just so much more powerfull evan at the lowest speeds.
06-05-2006, 01:34 PM | #43 |
Rock Crawler Join Date: Nov 2005 Location: Oak Ridge
Grover, You may want to consider replacing the plastic motor plate with an aluminum motor plate to eliminate the flex. Here is a link explaining the conversion: http://members.aol.com/neurazer/srt/JPC.htm How does the quark controller work for you? I have read that it has a tiny reverse delay. |
06-05-2006, 01:55 PM | #44 |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
He was able to finish the last run because of an acient 87T spur I had in my tool box....20+ years old LOL. Truck worked good.if ya need an alum motor plate to play with MLK I have 4 sitting on the bench right now
06-05-2006, 02:56 PM | #45 | |
Yeah, the Quark is MUCH quieter than the Mamba. When I build my next super, I think I'll give the Quark a shot. Loving your design. Once you get it "perfected", I would love to see a write up on it! Dez Last edited by dezfan; 06-05-2006 at 03:02 PM. | |
06-05-2006, 03:01 PM | #46 | |
06-05-2006, 03:04 PM | #47 |
Yup the Stealth rocks!
06-05-2006, 03:37 PM | #48 |
the reverse delay is noticable but as you said tiny. I belive I was able to make the speed control go thermal today...the heat on my rock pile was reading over 113 and I was pushing it real hard trying to get the new tranny case to flex and could not get it to. Unplugged the battery for a minute to let everything cool and then crawled with a bit more sanity.
06-05-2006, 03:40 PM | #49 | |
Chad- | |
06-05-2006, 03:48 PM | #50 | |
06-05-2006, 03:52 PM | #51 | |
They have a regular 2.2 class too. Whoop up on em! So if I read correctly, the uncut Pede gearcase is stiff enough to prevent the flex issue? | |
06-05-2006, 03:57 PM | #52 | |
06-05-2006, 04:00 PM | #53 | |
