Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya TLT Crawlers
Thread: TLT Build
Old 07-18-2006, 03:17 PM   #1
Default Vertical Smile-- Tlt
OK I don't have to many builds and felt that I was over due. Although I need to up date a couple of others.
This is what I have so far.
Vertical Smile Chassis of course, because there is no substitute for greatness.
2.2 pede rims
Moabs
Stealth Tranny
electrics??
The start..
TLT Bag O Parts
And the start of axles.
VS plates and a Delrin Skid/Brace 3" wide.
Just made the servo/upper link mount and 4 of the 8 4 links.
Crappy picture but I think you can make out what it looks like.
Last edited by Double J; 07-26-2006 at 12:51 PM. Reason: Change the name of the Tread
Double J is offline   Reply With Quote
Old 07-18-2006, 03:18 PM   #2
Have to lock the Diffs. with 2 part epoxy. I have another set to lock as well. So might as well do them all at once.
These gears and...
These gears.
Old 07-18-2006, 03:19 PM   #3
awsome so far i was going to get the vertical smile for my next clod project after my scale tlt.
rockschooler is offline   Reply With Quote
Old 07-18-2006, 03:22 PM   #4
I'm having the second run of plates getting done as we speak.
Old 07-18-2006, 03:27 PM   #5
cool it might be a little while though
Old 07-18-2006, 04:30 PM   #6
Default Partial roller
My crappy attempt at a crappy as5 teaser shot of a partial roller.
Old 07-18-2006, 04:31 PM   #7
Paypal....arghhhh!!
cartronicshn's Avatar
i'am waiting on mine , still undecided what to use as base
cartronicshn is online now   Reply With Quote
Old 07-18-2006, 04:34 PM   #8
I have to pick up some aluminum rod to get the links for you. And it will be sent out.
Old 07-18-2006, 05:37 PM   #9
Paypal....arghhhh!!
no problem i have a lot of unfinished projects .
Old 07-19-2006, 09:33 AM   #10
Sadly I do as well.
Old 07-19-2006, 05:12 PM   #11
this is the 1st Stealth Tranny that I'll be using and I'm trying to figure out how to attach the the Yokes to the tranny. I've been reading a few threads but would like to know what advise I could get on it?
Old 07-19-2006, 05:22 PM   #12
-Q-
Running maxx shafts? If so, this is what I did...
Take one of these:
Cut it to length to fit inside the drive cup, drill and tap it and stick a pin in it. (kinda screws your driveline angle, but allows for larger spur gears).
My first design was a machined one of these:
with the hole made large enough to slip over the Stealth drive cup with the pin through it. Worked well, but only allowed for about an 84t spur. I wanted more gearing options without the GD-600. Click the image to open in full size.
just my .02
-Q- is offline   Reply With Quote
Old 07-19-2006, 05:23 PM   #13
Can't see the pics
Old 07-19-2006, 05:27 PM   #14
-Q-
Can't see the pics
Fixed.
Old 07-19-2006, 05:34 PM   #15
I have the bottom one so I'll go that route. and was what I was planning on doing to begin with.
Thanks
Anyone else have ideas. As I also have these crappy little things.
Quickest picture I could find.
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN%3AIT&rd=1
Old 07-19-2006, 07:41 PM   #16
Get off my lawn!
microgoat's Avatar
Looks like you're off to a good start. You'll be surprised how much interest this will generate in your chassis, too. So spend a few bucks and make it pimptastic!
microgoat is offline   Reply With Quote
Old 07-20-2006, 09:44 AM   #17
I just had to pay to get the 2nd run of VS plates so I won't be able to spend the extra money I wanted to, to make it PIMPTASTIC. :(
Old 07-20-2006, 10:24 AM   #18
sweet keep up the good work
trickedoutTLT06 is offline   Reply With Quote
Old 07-20-2006, 02:21 PM   #19
Not much to say but here are some more pics.
yes crappy ones at that.
axle with the servo 4link on it.
Another angle.
The chassis w/ all 4 links on... Not to bad of a pic.
another..
Old 07-20-2006, 03:01 PM   #20
Paypal....arghhhh!!
looking good, when are you starting the tranny build up? maybe you can give me some pointers on my build
