01-10-2007, 09:47 PM | #41 |
Pebble Pounder Join Date: Oct 2006 Location: under a rock
Looks good man, love the bta steering been working on that my self |
01-10-2007, 10:04 PM | #42 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
Ok, I have the drive train mocked up. The slider will be operated by a micro servo. The pilow blocks will be machined from black delrin to support the drive shafts. I also geared the tranny with a 12 tooth pinion and an 87tooth spur, I have a 96tooth if need be.
01-10-2007, 10:07 PM | #43 | |
01-10-2007, 10:08 PM | #44 |
Looks good! Keep it coming! |
01-10-2007, 10:12 PM | #45 | |
01-11-2007, 01:20 AM | #46 | |
RCC Addict Join Date: Jan 2005 Location: Green River Kentucky
Careful man Some of us DO own a patent on L channel Cant wait to see how this does against the real deal at joey's. looking good so far man keep up the good work. | |
01-11-2007, 10:04 AM | #47 |
RCC Addict Join Date: Sep 2005 Location: ...Here & There
I can't wait to see this rig perform! It looks like it'll work verry well! See you next month Jeff! Last edited by TwistedXT; 01-11-2007 at 06:40 PM. Reason: It wasn't very nice of me, to point out the obvious... |
01-11-2007, 03:49 PM | #48 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
here's an idea if your micro servo isn't strong enough for some reason. Mount a standard servo on the axle inline with the backbone, then run a linkage from the servo to your slider. That way it won't hurt your COG as badly as mounting it on the backbone. Honestly though, I think that setup should work very well exactly how it is. Especially with the driveshaft held stationary like that. Last edited by TwistedXT; 01-11-2007 at 06:41 PM. |
01-11-2007, 04:13 PM | #49 |
01-11-2007, 05:03 PM | #50 |
Rock Stacker Join Date: Jan 2007 Location: some where
i like the torsion design
01-11-2007, 06:06 PM | #51 |
Alright, today I got the tranny locked up, I locked the slipper and the dif. Then I got the pede yolks adapted to the stealth outdrives. Then I installed the tranny and did the driveshafts. All thats left on the drivetrain is to make the pillow blocks and the slider. I threw some electronics in it when I got home just to see how it was working, I have now learned that the most important thing with a torsion is weight distrabution. So I am going to run those big ugly c cells that I like so much and put some weight in the back. Surprizingly the 65 turn motor I threw in there felt pretty good, I figured it would be to slow, might run it for a while, or a 55t. Anyway the breakover angle is unreal. I was climbing the steps in front of the house with it, the only failure I had was I cut my front driveshaft down to short and it poped out a few times, but that will be fixed with a longer spline engagement. Since it was to dark out to get any video I risked life and limb for a quick shot at some mattress crawling, its got better groung clearance than the Imperial does......... by about an inch, not counting the links that are even lower. MattressCrawling |
01-11-2007, 06:32 PM | #52 |
Its that youlk that I have ziptied to the frame, it will go away when its done.
01-11-2007, 06:35 PM | #53 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
that looks killer! Any pics of how you mounted the tranny?
01-11-2007, 08:18 PM | #54 |
Sure here you go.
01-11-2007, 08:46 PM | #55 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
lookin good.
01-11-2007, 08:55 PM | #56 |
Rock Crawler Join Date: Jun 2006 Location: Santa Rosa
if it was climbing stairs that is pretty good. Cant wait to see a vid
01-11-2007, 09:19 PM | #57 |
Well, every project needs a name and after much consideration I have settled on the following........ The JAP Just Ain't a Pimp JB I hope you don't mind the reference, just paying tribute to the original. Last edited by Kamikaze; 01-11-2007 at 09:24 PM. |
01-11-2007, 09:23 PM | #58 | |
01-11-2007, 09:56 PM | #59 | |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
01-12-2007, 09:31 AM | #60 |
Patience my friend, yours is next!
