03-20-2007, 09:43 AM | #41 |
RCC Addict Join Date: May 2005 Location: I live Here
wow ! ! ! ! ! just put together the roller and if a i hold with my hands and flex it it goes toooo much it articulates 90 degrees! ! ! ! with out holding just the weight of the car it will do just under 45 here are some pics for the XRC GURUS so they can check the setup it sits at 12.5 to the dot thanks in adcance fo rthe comments |
03-20-2007, 09:49 AM | #42 |
RCC Addict Join Date: Feb 2006 Location: UrAnUs
lookin' good but may i suggest that you lowerd the ride height by mounting the shocks farther back well you dont have any electronics as well as tranny and motor so... |
03-20-2007, 09:52 AM | #43 | |
just measured you are right it sits at 3.5 with out weight might relocate the shocks more i have seen david draw some lines on the pics ..... what are those for and what do they mean ? ? ? Last edited by chivas72; 03-20-2007 at 09:55 AM. | |
03-20-2007, 10:10 AM | #44 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
As far as articulation goes. I have 1/2 fule tubing on the outside of my shock shafts. I am thinking of going to 5/8ths because it still flexes a little much. I won't go to a smaller shock or lower ride height because of the break over I like so much. Using a stealth tranny, revolver motor and a quark speedo I have really no weight up top so CG is still low.
03-20-2007, 12:44 PM | #45 |
| new pics
relocated the shocks lowered it to 3 inches under the belly see what you guys think |
03-20-2007, 02:20 PM | #46 |
are the tranny bolts supposed to come out of top the tranny thru the plastic ? ? ? if not damn i messed up |
03-20-2007, 02:22 PM | #47 |
Pebble Pounder Join Date: Jan 2007 Location: Southern IL
Lookin good. I'm waiting on my XRC package 4 to come in. Did it take awhile for you to get yours in the mail?
03-20-2007, 03:04 PM | #48 | |
RCC Addict Join Date: Mar 2006 Location: Bedias, Texas
Sincerely, David Xtreme Rc Hobbies | |
03-20-2007, 03:20 PM | #49 |
Hello chivas72, it looks like your build is shaping up very nice. On the screws coming out of the tranny unlees they are in the way of something or you don't like the way they look I'd just leave them. If you want or need to you can cut them down with a dremel tool. Your shocks are laid down a little too much for me. What we do is limit our shocks internally so that unspung they are actualy shorter, and you can stand them up more, and decrease articulation at the same time. We have a section on our website showing exactly how to do this shock modification. Your link geometry looks to be preety good depending on what you are shooting for. If you have the upper link close to level you should be good on your antisquat (as). David Xtreme Rc Hobbies |
03-20-2007, 04:12 PM | #50 | |
03-20-2007, 04:30 PM | #51 | |
i say it took about 4-5 days | |
03-20-2007, 09:09 PM | #52 | |
Quarry Creeper Join Date: Jun 2005 Location: quarryville
03-21-2007, 07:10 AM | #53 |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
I agree with David on this, the shocks look too laid down. I have an XRC-CF and when I lay the rear shocks down, it seems the back end is too floppy. It also has more torque twist when the shocks are laid down. Limit the shocks with some fuel tubing, stand the fronts more upright (to limit some twist and eliminate torque twist). Then get out and test it. I am still making changes trying to find out what works best for me. That is what it is about, what works for you. Thanks, Casey |
03-21-2007, 11:50 AM | #54 |
mine is a 50-50 set up i got the shock shortening deal purty good what shock length for a 50-50 do you recomend ? ? ? measurement is from eye to eye or tip to tip ? ? ? |
03-21-2007, 01:51 PM | #55 |
shortened the shocks to 3.5 inches from eye to eye, shock travel .75 inches limited flex to about 45 degrees, under belly clearance 3 inches, but wb went to 12.75. back to the drawing board till i hit 12.5 any suggestions ? |
03-21-2007, 02:15 PM | #56 |
Did you clock the rear axle (point the output from the rear axle upwards) to create more of a strainght line from the transmission output to the rear axle output? If not, doing this will shorten your wheelbase slightly. An easy wat to do this is to make some longer upper rear links. But, as you do this, you lay the rear shocks down more. I have made an extension to mount to the chassis to stand the rear shocks up a little more with the clocked rear axle. I will try and get some pix up in the next couple of days of my new set up. Hope this helps some and isn't too confusing.
03-21-2007, 04:48 PM | #57 | |
Pebble Pounder Join Date: Aug 2006 Location: Albuquerque
03-21-2007, 04:52 PM | #58 | |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
03-21-2007, 05:24 PM | #59 |
The only thing I can think of is that when the travel was limited it made the links more horizontal. So at rest, the WB would be longer. As the links moved to the other extreme of their arc they would decrease in WB.
03-21-2007, 05:58 PM | #60 | |
i decided to re-lengthen the front and move one hole back and down this gave me back the 12.5 and 3.5 under beely i will post pics up tomorrow good night ! ! ! | |
