03-21-2007, 09:31 PM | #61 |
RCC Addict Join Date: Feb 2005 Location: Minneapolis
Also, shortening the ride height (belly clearance) can lengthen the wheelbase. I think it can actually change it by about 1/4".
03-23-2007, 09:56 PM | #62 |
Quarry Creeper Join Date: Jun 2005 Location: quarryville
insane you dont happen to know where i can see some pictures of this do you ? i have a pede speed controller... and im kinda lost to what you were saying now:-(
03-26-2007, 05:13 PM | #63 |
RCC Addict Join Date: May 2005 Location: I live Here
| batteries
thinking of getting 6 cell 4/5A battery pack 2000mah nimh in brick lay out are these too big ? ? ? the sub c stick pack that i run on my sw2 is too big and is affecting the approach angle this is bashe so longer run times are of the essence, any other suggestions ? ? ? |
03-26-2007, 05:28 PM | #64 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
I am running these. 1400 mah and light as heck. I ran 3 courses in UT weekend before last on one pack. I have it velcroed to the top of my servo and just sits on top of my links. For $29 done you cannot beat them.
03-26-2007, 05:32 PM | #65 |
so this config sits better ( shorter ) than the twin stick ? ? ?
03-26-2007, 05:34 PM | #66 |
I like it. Of course I have limited my shock travel so hitting the chassis brace is not an issue.
03-26-2007, 05:51 PM | #67 |
how's this sound 6 sc in either of these configs or i kinda like the second choice to keep cog lower but need to go home and measure |
03-26-2007, 05:52 PM | #68 |
The top pic shows 9 cells.
03-26-2007, 05:54 PM | #69 |
03-26-2007, 05:56 PM | #70 |
6 sub C's in my opinion are too heavy up top like that. I would stay with 2/3 AA's if possible. |
03-28-2007, 08:44 AM | #71 |
Rock Stacker Join Date: Aug 2006 Location: South Charleston
I have been working on my XRC, it is the 60/40 setup. The front drive shaft hits the skid plate. Is there something i missing here. Ride height is 3-3/8" so it sits pretty good. I am running a aluminum pede tranny. Any ideas on how to solve my problems or anyone else had similar problems?
03-28-2007, 08:56 AM | #72 |
Dremel out the skid where it hits.
03-28-2007, 09:03 AM | #73 | |
RCC Addict Join Date: Mar 2006 Location: Bedias, Texas
johnrobholmes is exactly correct. We do not notch or bevel skid plates for drive shaft setups due to the large variety of configurations. David Xtreme Rc Hobbies | |
03-28-2007, 09:10 AM | #74 |
It would be impossible to guess at them all. My SW2 even had the driveshafts hit, and that skidplate is super tiny.
03-28-2007, 09:17 AM | #75 |
Thanks guys, thats what i figured I would need to do. I was just wondering if anyone else had the problem and what they did.
03-28-2007, 09:45 AM | #76 |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
When in doubt... Hogg it out. |
03-28-2007, 09:45 AM | #77 |
on the 50/50 setup i have on both sw2 and my daughters new xrc i have no driveshafts problems sw2 runs maxx shafts and the xrc is running pede shafts |
03-28-2007, 09:47 AM | #78 |
03-28-2007, 09:55 AM | #79 |
03-28-2007, 10:02 AM | #80 |
I'm also gonna have to grind some of the chassis plate away too so my motor will fit. I have a integy 50 turn hand wound for it but it wont fit. I have a 55 turn integy and it will fit, I guess its the difference in the end cap. The 55 was robbed from my clod so I could mock up. It might be because of the aluminum case pede tranny. I might need to get a plastic cased one, especially to save some weight.
