04-02-2007, 05:25 PM | #21 |
RCC Addict Join Date: Mar 2007 Location: des moines
befor wideners after wideners steering |
04-08-2007, 12:06 AM | #22 |
I took the truck crawling today and I just wasn't happy.I changed out the pedy tranny for a r2 tranny to try an low the c.o.g alittle here some pics of the tranny here is a short vid its kinda ****ty http://s67.photobucket.com/albums/h3...t=DSCF1067.flv |
04-08-2007, 08:02 AM | #23 |
RCC Addict Join Date: Sep 2005 Location: Tempe, AZ
Sweet...that's how I mounted my R2 as well....
04-08-2007, 09:48 AM | #24 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
looks good complete. they are an impressive chassis. i hav eone also. it does real good.
04-08-2007, 10:29 AM | #25 |
04-08-2007, 12:32 PM | #26 | |
Same question about 3013 and the R2 trans...I am running it with WK axles have different reduction. What is the reduction on TLT's and what pinion are you running in the r2? | |
04-08-2007, 12:55 PM | #27 |
Rock Crawler Join Date: Jul 2004 Location: Salt Lake
I love the way sw2's look when they're cut down like that. Great job on the build!
04-08-2007, 12:56 PM | #28 |
Im going to try a 15t pinion and see what that dose if I need to go lower I will have to have the shaft turned down.thanks sw2 is a great chassi modded or unmodded.
04-08-2007, 06:48 PM | #29 |
Quarry Creeper Join Date: Oct 2006 Location: wollongong, NSW, Australia
The truck looks great I believe DTP also has a cut chassis Shane |
04-12-2007, 07:00 PM | #30 |
04-12-2007, 09:45 PM | #31 | |
Quarry Creeper Join Date: Mar 2007 Location: Celina TN.
| Swappin a R2 Quote:
04-12-2007, 11:05 PM | #32 |
no you should not have to do anything to the chassi.my chassi was modded to look like benders sw2. I found my sw2 to work better with the pedy in it |
04-13-2007, 07:05 AM | #33 |
I ground out part of the lower brace so that the tranny would sit flat on the skid and then drilled holes in the skid and counter sunk them and drilled two holes in the other side plate. I also notched the plastic gear cover on the trans. Check it out hear WK SW2 Build |
04-13-2007, 08:42 AM | #34 |
Great,thanks for the replys and clarkrw3 thanks for the pic got it saved for refferrence.i
04-13-2007, 08:44 AM | #35 |
04-15-2007, 05:30 PM | #36 |
I just got back from my frist comp.truck did great.I bent the chassi to hell I jumped it off a 6 foot rock and landed on the lid:-(
04-15-2007, 05:55 PM | #37 |
09 RCA champ! Join Date: Sep 2006 Location: Acworth, Ga
id like to know where the chassis bent...
05-01-2007, 03:45 PM | #38 |
did some grinding on the hubs today got alittle more steering |
05-01-2007, 03:48 PM | #39 |
some pic from the last comp i was at :-( |
05-02-2007, 12:54 AM | #40 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
Looks cool, where did it bend at hopefully it was just the center braces and not the actual chassis. |
