![]() | #41 |
Quarry Creeper Join Date: Mar 2006 Location: Manitoba, Canada
why this is fine for now and works
![]() | #42 |
mounted everything just for the time being, loving it. one thing though, my futava 23305 high torque metal gear servo hardly moves the tiniest bit, whats up with that?
![]() | #43 |
Keep it real ![]() Join Date: Jun 2006 Location: Yakima,WA
It doesn't have the power you need. Look for a servo with a minimum of 200oz or more, depending on your budget.
![]() | #44 |
what do you mean it doesnt have the power i need? even with the wheels up in the air it wont fully turn. hopefully my charged battery will help :P litterally just need a peice of velcro and its done. velcro for mounting the radio to the underside of the hard body, need to velco cause it needs to come off to plug in/out the wires that go to it, too hard to do with while trying to put the body on all at once. ![]() ![]() ![]() ![]() ![]() |
![]() | #45 |
oh ya, general lee paint job coming up, some of those decals may be coming off
![]() | #46 |
OK, somethings to check. Yes, charge the battery ![]() |
![]() | #47 |
dont know about the radio and EPA, i can try and find out. Its a radio out of a savage 25 (HPI) i will check. there is no binding, it moves very nicely, the servo is brand spanking new
![]() | #48 |
Looking at your pics, one thing I noticed is, instead of having the tierod under the knuckles and using a spacer for the draglink, move the tierod on top of the knuckles and ditch the spacer. It will give you a better approach angle. If the servo is new, and there is no binding, and the batt is charged, only thing I can think of is End Point Adjustments(EPA's) |
![]() | #49 |
how can i adjust the EPA? does the savage radio have an EPA? I am still looking to see. also i will try with full battery
![]() | #50 |
I haven't used any HPI radios, so I can't say for sure if they do or don't have EPA's.
![]() | #51 |
i dont think so, anyway i can get around it?
![]() | #52 |
If the radio doesn't have EPA's, then they aren't limiting your steering. My theory was maybe your EPA's were set too low to let you get the full throw out of your steering.
![]() | #53 |
oh ok so its not a bad thing then if it doesnt have it, whew. if it does i should be able to adjust it on my transmiter?
![]() | #54 |
Yes.
![]() | #55 |
alright i just tested it with a full bat. it turns more then it did so thats a good sign, im thinking the rest can be adjusted with the steering trim. one question though, is it safe to turn the servo by hand when its all shut off?
![]() | #56 |
I do it all the time, but I don't really know, if you're not supposed to do that.
![]() | #57 |
yeah, same question with the motor, is it safe to turn it by hand when its all shut off
![]() | #58 |
![]() | #59 |
sweet. thanks dude. now i just gotta go to bed so i can wake up and play tomorrow! will have 2 full batteries ![]() |
![]() | #60 |
Rock Crawler Join Date: Aug 2006 Location: nc
make sure to get pics while your playing
