10-22-2007, 05:13 PM | #61 |
Thanks guys, and yes, I do LOVE this chassis!! It felt good to know that I was able to beat Hackster, Miniwheeler, Grover, Warpig, among others.........oh yeah, and Brittany. :-P
10-22-2007, 05:32 PM | #62 |
A couple of pics from the series finale that Scuzzy took, thanks Dustin |
10-22-2007, 05:36 PM | #63 |
Hey nice job man!
10-22-2007, 05:51 PM | #64 |
Rock Crawler Join Date: Apr 2006 Location: pasco,Wa
congrats bud,wish i could have made it.
10-22-2007, 08:04 PM | #65 |
Quarry Creeper Join Date: Aug 2006 Location: On A Big Pile Of Rocks
Congratulations to you and Britt. Chimney |
10-22-2007, 11:59 PM | #66 |
Thanks guys, it was a fun comp and series overall. |
10-29-2007, 12:51 PM | #67 |
10-29-2007, 02:36 PM | #68 |
Rock Stacker Join Date: Sep 2007 Location: Seattle
One other thing I noticed, is your R2D angled a bit? What's the purpose for that? Nice idea there with those servo mounts You sure did get that chassis loaded up there quite well |
10-29-2007, 03:59 PM | #69 |
The reason the tranny is angled, before I put the R2d in it, I had just the standard R2, the chassis was flipped around so the motor was facing forward, and I angled the tranny down, so the motor was lower at the front. The front of my chassis is also lower than the rear. It's a little trick I picked up from Warpig to get your CG down a little. Since I had to flip the chassis around to make the R2d work, I didn't feel like making a new mount for the tranny, so I left the one I had in it alone. It angles the wrong way now and is why I had to use a Revo shaft on the front driveline, the angle was too extreme for anything else to work. I haven't noticed any ill effects from doing this, but I might make a new mount for the tranny one of these days. Still crawls well enough to beat 53 other trucks at our series finale, and there was some serious talent on hand. And yes, I might be able to shoehorn something else in the chassis........OK maybe not |
11-15-2007, 02:23 AM | #70 |
Quarry Creeper Join Date: Aug 2004
What link mounts holes do you use? and are you still on the blac and white spring combo with 30wt oil? I have my sw3 working better then Scooters sw2, it was a cobination of tires and track width. thanks for the impending help ;) -peter- and what did you make or mod the skid with? I read the thread and I saw a mention of a new skid, but from who/were/what/why.... :/ |
11-15-2007, 06:52 AM | #71 |
RCC Addict Join Date: Mar 2006 Location: Xxx
I own this rig now and have since redone the shocks with 100wt in the front and 5000 in the rear . Here are pics from when I first got it. The original mounting before I revamped the truck . If your refering to the spring in the above pics above mine they are yellow fronts and purple rear. Not sure of what manufacture makes them. Last edited by PROTOTYPE; 11-15-2007 at 06:54 AM. Reason: Added crap. |
11-15-2007, 09:04 AM | #72 |
Rock Crawler Join Date: Sep 2004 Location: South Orange County
looks like a great setup 5000 shock oil? is it a nitro buggy diff fluid the 5000? |
11-15-2007, 04:31 PM | #73 | |
Skidplate......PM FinishlineRC. | |
11-15-2007, 04:34 PM | #74 | |
I'm curious, how has the heavier shock oil changed the performance on yours? | |
11-15-2007, 05:24 PM | #75 | |
I am using the same link points as you are. BUt I noticed with the r2-diso mounted up my front upper left link touches my driveline to stop my articulaion. only like 5mm, but is not cool! I have 25wt oil f/r and losi pinks up front and duratrax whites outback... how wide is your truck? outer edge of the tires? ran mine some more today and I think I am a m2k guy.. thanks Nathan, you da'man..... -peter- | |
11-15-2007, 05:44 PM | #76 | ||
WOW your a sneaky man having to identical rigs . I underestimate your sneakiness. The paint job is superb I know . And thank you for the compliments. I have noticed that it allows the suspension to cycle a lot slower which is what I use to my advantage with my driving style. I don't use the same shocks I did not like them They leaked alot from the cap and the bottom. I do use adjustable shocks still. With the slower reaction I feel that the truck side hills and is more steady on the ascent of hills. This chassis is da shiz nit . Lots of adjustablilty. The best | ||
11-15-2007, 06:06 PM | #77 | |
I am 10 1/8" front, 9 5/8" rear, with the claws. Last edited by Tanis; 11-15-2007 at 06:15 PM. | |
11-15-2007, 06:12 PM | #78 | |
Yes, the SW3 is sweet(especially with that custom skidplate), I won't run anything else in a comp. | |
11-15-2007, 08:11 PM | #79 |
I am running the KYOSHO LAZER ZX-5 shocks. Only these and the new TEAM LOSI shocks are what I run. Seems they know how to make a leak less shock . Also the Kyosho ones are nice and thin . I also use the piston disc with 3 holes in the front and 2 holes in the rear. With the colder weather around here I also add weight to the rear to have the rear end drop a little quicker . Cold weather and thick oil makes for a coagulative combo. One thing still boggles my mind is your wiring that you had . I am still to cautious to tear into and rewire it. Everything worked FINE , Its just my electrical abilities are on the newbie side . And to think I was going to trade the SW3 for a tube chassis. Screw that noise , I'm all about perfection. |
11-15-2007, 09:34 PM | #80 |
