02-27-2007, 03:37 AM | #41 |
Rock Crawler Join Date: Aug 2006 Location: sleeping in my truck!
thanks for the props guys, probably after this weekend c3po gonna get bus' up on the rocks...............but it's all good! |
02-27-2007, 03:38 AM | #42 |
Rock Crawler Join Date: Sep 2005 Location: IDK
Wow!!! That thing is looking great!!! This txt stick is looking way better then mine How did you paint the body (airbrush?) How did you wire up the RX ? with Y-wires? or did u just put it in the Batt slot? Good job !! |
02-27-2007, 03:43 AM | #43 |
painted the body with airbrush.........fascolor blue pearl, fascolor black, mixed some fascolor pearl green, blue, and some black to make the darker blue, and spaz chrome for the flames. the darker blue is marbleized just like the 2.2, can't see it in the shade but it comes out in the sunlight. the rx is connected to the battery side, 5 cells. thanks for the compliment, yours looks killers too . too bad you're not close by, would be cool to see your's in action too.
03-24-2007, 10:27 AM | #44 |
I'm liking this truck. How is it holding up? Getting better as it crawls more? I'm going to try a 2.2 version today and see how it works out. Nice work |
03-24-2007, 11:59 AM | #45 |
it's holding up pretty good. gonna comp it again on sunday. did great on it's first time out at the last comp, came in first on its maiden voyage. let's see about this weekend. i have a 2.2 version called "pimping r2d2" i love these torsions, never going back to 4 link again. thanks for the compliments, and good luck on your build
03-29-2007, 05:37 AM | #46 | |
REST IN ALOHA CHIP Join Date: Nov 2005 Location: *
posted back in january, now this fawker has two torsion rigs | |
03-29-2007, 06:35 AM | #47 |
03-29-2007, 03:22 PM | #48 |
I was talked into trying torsion, and I am impressed with their capabilities. |
03-29-2007, 06:27 PM | #49 |
Newbie Join Date: Dec 2006 Location: bristol
so simple and cheap does it work good i have txt axels and tring to decide on a chassis that looks like a possiblety thanks
03-29-2007, 07:08 PM | #50 |
| it works awesome............you can climb over things that you never thought possible. the clearence is wonderful, and you can cross over holes that others would get their wheels sucked into. you will not be disappointed if you do it, trust me.
03-29-2007, 09:18 PM | #51 |
I agree. |
04-01-2007, 08:45 AM | #52 |
Newbie Join Date: Feb 2006 Location: hazed from that last one
just wanted to say that your rig has kinda inspired me. i have a set of savage axles and have totally decided to make it torsion. 1 ? though. what thickness is the aluminum??
04-01-2007, 07:12 PM | #53 |
the aluminum backbone is 1"x1"x1/16". i found some at the jobsite and it's alittle stiffer than the ones that homedepot sells. you could probably get away with 1/8", depends on how soft the aluminum is. just try twisting before buying. it's all a personnal preference. good luck on your build.
