07-04-2007, 07:35 PM | #21 |
RCC Addict Join Date: Feb 2005 Location: Vancouver Island B.C.
The 5955 only travels 90*, where the 5995 will go 180* and need a radio with EPA's. I spent all my $$$ on servos so im stuck with a modded TQ3 haha.
07-05-2007, 09:18 AM | #22 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
Verry cool looking rig.
07-05-2007, 08:18 PM | #23 | |
RCC Addict Join Date: Mar 2007 Location: Penngrove
word man thx, I just picked up a 5955 at my LHS as well as a 1400mah reciever pack. I think i also figured out that the motor was trippin on the fact that i had a 6mm hole in the shaft and 5mm output on the R2. the uneven rotating mass messed with the comutation of the motor. I may have to take back my statement about the 3014 in a TXT! | |
07-05-2007, 08:55 PM | #24 |
hey, if run 2x 5955's and a 1400mah reciever pack what voltage reg do you guys recomend? I assume i need at least 7Amps, is this true?
07-05-2007, 10:37 PM | #25 |
| Looks like the 5955 only turns 60 deg andI also found out that 5995 pulls a ton more current. I think the sick set up would be a 5995 up front and the 5955 in the rear.
07-06-2007, 09:14 AM | #26 |
RCC Addict Join Date: Sep 2005 Location: Tempe, AZ
07-06-2007, 01:11 PM | #27 |
Weird, all my 5955's turn 90* when they arent hooked up to the truck but plugged in, and my 2.2 turns very close to 45* each direction and its not limited by the servo. Did you adjust your EPA's? I have never ran a 5995 since i have a crappy radio without EPA's, and wont have a good radio for a while. As for voltage regulators, i dont know much about them but i bet all you do is add you peak amperage demands up to figure out what to set it at.
07-06-2007, 09:56 PM | #28 |
Quarry Creeper Join Date: Jan 2006 Location: ---EAST--TN---
Dont you also need EPAs with the 5955s? Everything Ive heard says you need EPAs with any digital servo. Ive run the crap out of the TowerPros without EPA so I guess they dont. But I thought any of the High dollar Digitals need it?? |
07-07-2007, 05:39 AM | #29 |
Quarry Creeper Join Date: Oct 2006 Location: wollongong, NSW, Australia
This is one of the nicest tubers I have ever seen Shane |
07-07-2007, 11:52 AM | #30 |
RCC Addict Join Date: Nov 2005 Location: Utah
This looks like a clod killer? maybe? Dang nice work!! Puts other well known tubers to shame |
07-07-2007, 10:45 PM | #31 | |
I almost have the rear steer done but Im having a hard time setting up my Futaba 3PM to make it work the way I want it | |
07-09-2007, 09:19 PM | #32 |
Update: I got my 4-wheel steering up and running this weekend, 5995 in front, 645 in rear, took forever to program my Futaba 3PM to do 4whl and crab walk, but now it works super sweet. After only two battery packs with the brushless I totaly fried my Crawlmaster lastnight. I noticed it was hot after the first pack but I read a post by JRH stating the 3014 can take 600W and get up to 300F before it's toast. I swapped in my 55t integagy hand wound and man does the thing cook now. lots of control and wheel speed, it could be a 65t or a 6t and be perfect. |
07-09-2007, 09:35 PM | #33 |
I was thinking a while back in this thread that you needed a 3025 for that rig...not that the R2 would hold up to it....lets see the update pics
07-09-2007, 10:59 PM | #34 |
I guess to pull off a 3025 id either need the stock or emaxx tranny since they were designed for two motors. I think that and even with one of those trannies clocked I think it'd still have too high of a CofG. Heres some pics with the integy, 4ws, dial'd in shocks, etc |
07-10-2007, 08:23 PM | #35 |
Flex pics (the last two are not poser's) |
07-11-2007, 06:51 AM | #36 |
RCC Addict Join Date: Apr 2004 Location: 5280
Did you ever think about trying a gear reduction unit ahead of the R2 to help the motor out?
07-11-2007, 09:50 AM | #37 |
Moderator Join Date: Apr 2004 Location: In my head
Looks good! How is the torque twist with the droop set-up?
07-11-2007, 09:57 AM | #38 |
very cool build, can't believe I have not seen this yet if this is only your third rig, I'd say you are way ahead of the curve. Very nice work indeed. I would angle the shocks a bit more and lower your ride height, also looks like you may need thicker shock oil or stronger springs to limit some of the torque twist and flex. Overall, I love it, nice to see something different for sure. |
07-11-2007, 09:42 PM | #39 | ||
unimoger, I see what ur saying about the front shocks, it allows the front to drop out way too much, i think i will move the lower mounts forward like a 1/4"or more | ||
07-14-2007, 10:55 AM | #40 |
Pebble Pounder Join Date: Oct 2006 Location: Leaving black marks on Hwy 200
What kind of run times do you get with that battery setup?
