09-18-2013, 01:59 AM | #1 |
Rock Stacker Join Date: Jul 2013 Location: Vancouver BC
| Need help upgrading cc-01 motor & esc
Hey guys Just got a cc-01 wrangler jeep, Looking to upgrade the motor so i can get more power, torque, and crawl better Also looking to upgrade esc my budget is around $150 for the two , please feel free let me know what youd reccomend for me, also if you have any more tips for this feel free to let me know. Thanks guys Heres a shot of the project so far.. |
09-18-2013, 02:36 AM | #2 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
I'm pretty happy with my cheap 55t motor (Low Bucks Racing) and a used Tekin FXR. Good low speed control and still able to kick up some little rooster tails.
09-18-2013, 07:26 AM | #3 |
Pebble Pounder Join Date: Dec 2011 Location: shelby
| Re: Need help upgrading cc-01 motor & esc
Yep for trail running and crawling you can't beat a good ol' axial 55t. They cost around 20$. As for esc the ae2 that axial has is great, it is a rebranded castle esc and can be programed with a castle link. Those two can be had for well under 100
09-18-2013, 03:48 PM | #4 |
Pebble Pounder Join Date: Jul 2009 Location: Australia
x2 for the CC speed controller,being able to program it with drag brake,lipo cut offs,motor type and power control,all with the click of a mouse is just great and dead easy to use.Personally i use a piece of crap esc that i found in my junk box covered in silicone for water crossings but the Castle Creations stuff is about the best you can get imo. Dig around looking for mods on the net,for me,modifying the front "C" hub things with a grinder (or the control arms) to get more downtravel in the front made a big difference.I would replace the rear links too,at least the bottom ones.Buy a bearins set for your CC01,makes a ton of difference.Also i would buy the gpm steering kit,put it together with blue loctite and tighten it down pretty good.I would get a stronger servo too,you don't need a mammoth thing, just something with metal gears and a bit more grunt. Another massive thing i found (probably because i'm running a cheap esc) is i needed more power for the servo.Find yourself a BEC.Either way they are a good thing to have and gives you much better steering response.You can make a bec with a cheap one online for a few bucks and some connectors and some wire.It will go between your battery and esc then plug into your receiver where is says battery delivering 5V straight into the system. I would also consider a 3ghz system as well for range and to help with any glitching. I'm a cheap ass so these mods aren't expensive to do.For the radio gear i got a dirt cheap Chinese $15 dollar unit (or $30,can't remember) and it works just fine. Good luck,Happy wheeling. |
09-18-2013, 03:50 PM | #5 |
And cut that brick off the front.lol
09-18-2013, 08:55 PM | #6 |
Nice! I'm currently working on building a CC-01 Jeep Wrangler. Are those Integy wheels? And is that a CR-01 in the back? |
09-19-2013, 07:59 AM | #7 |
thanks for all the help guys. I think ill do a 55t with a programmable esc. already got a hitec servo ready to go in. stay tuned!
09-19-2013, 08:02 AM | #8 | |
| Re: Need help upgrading cc-01 motor & esc Quote:
2 : nope, its my custom built jeep. if you wanna see more pics hit up my started threads & its the one with "tbh2014's green apple jeep build" its a monster 2.2 scaler/crawler hybrid 1:10 build of mine | |
09-19-2013, 09:10 AM | #9 |
Topcad = Integy. Same stuff. Nice wheels for the price for sure. Agreed, simple 55/65t motor + AE2 will do the trick. Great set-up for the CC chassis. |
10-13-2013, 10:09 PM | #10 |
Quarry Creeper Join Date: Sep 2013 Location: New Zealand
Castle Creations SV3 Esc and a Novak Rock Star 55T motor? I reckon that'd be good......
10-17-2013, 05:43 PM | #11 |
Newbie Join Date: Oct 2013 Location: Toronto, Ontario
On my CC01 Pajero I run a cheap $15 esc off ebay and an axial 55t and am very happy with it. Great looking Jeep.
Need help upgrading cc-01 motor & esc - Similar Threads | ||||
Upgrading motor esc servo | SMITHJEEPS | Axial AX-10 Scorpion | 23 | 04-29-2011 08:13 AM |
upgrading motor and esc | TJ36s | HPI Wheely King | 13 | 04-09-2011 09:08 AM |
Question about Upgrading Motor & ESC | netsurfr | Losi Mini-Rock Crawler | 4 | 03-02-2011 07:11 PM |
