03-20-2014, 09:48 AM | #1 |
Newbie Join Date: Aug 2011 Location: Topeka
| Problem in drivetrain
I picked up a CC01 in trade about a year ago. It had some issues when I got it and I can't for the life of me get the bugs worked out. I put in all the electronics and it seemed to work okay until I tried to go over some rocks. What happened is that when the drive train is put under tension, the front diff clicks and the tires won't turn. Whats really strange is that if I move the pinion backward on the motor shaft the problem will move to the rear diff. A couple of the chassis screw holes are a bit worn. I also think that the motor mount is flexing under torque thus causing the strange issue with the pinion placement. What I think, and please let me know if you have any experience with this, is that if I epoxy shut the chassis mount holes and re-drill/tap them and get a metal motor mount the problem will cease. Anyone encounter this before? |
03-20-2014, 11:45 AM | #2 |
| Re: Problem in drivetrain
Yup. Screws are not holding the cover down tight enough allowing the internal gears to walk a bit. Very common issue. Slightly longer machine screws may help, but will wear out eventually too. Best bet is to drill them out completely, get some longer machine screws, and then bolt them from the bottom of the chassis. Holds the cover tight and is far easier than filling, drilling and tapping. Might be a good idea to pick up a new set of gears too while you're in there. Usually they just click - if they are skipping that bad, probably a good idea. |
03-20-2014, 12:23 PM | #3 |
I'll try that. Thanks OSRC.
Problem in drivetrain - Similar Threads | ||||
EXO drivetrain problem. Please help. | Soulo747 | Non Crawler RC's | 3 | 04-12-2012 10:19 AM |
Help with Drivetrain! | Reaper09 | Large Scale Rigs | 6 | 05-01-2011 12:31 PM |
Losi Mini Crawler drivetrain problem | ausjethro | General Crawlers | 2 | 04-26-2011 02:22 PM |
Drivetrain problem with my R1... | iheartoldskool | G-Made Crawlers | 6 | 08-08-2010 08:37 PM |
drivetrain problem | wojin | Axial AX-10 Scorpion | 18 | 08-17-2008 01:20 AM |
