10-23-2014, 01:28 PM | #1 |
Pebble Pounder Join Date: Sep 2012 Location: Kansas City
| New to me CC01 Jeep Wrangler
So I inherited a CC01 Wranger from my best friend who died up in Michigan. I have never had a Tamiya and it is entirely different than other crawler I have and have had. I would like to build a scaled out class 1 rig out of it that I can take out here and there or let friends use but I have some questions..... Here is the rig as it sits... And on to the questions... 1. What is this "black brick" people have said to remove? It is quite possible my buddy already took care of that but I want to make sure. 2. It appears to have aftermarket knuckles(Aluminum and say HR on them) and aftermarket aluminum rear link setup with aluminum "C" plates that they attach to that wrap over the axle. Is there other mods I should look into to get it properly reliable and efficient as possible? 3. Like I said I want to make a class 1 rig out of it and it will see its fair share of water. I plan to cut some styrene and seal off the battery slide in and space between the front wheel wells to help keep as much water out as possible. Is there any other inherit things I should do to help water prepare it?(besides general electronics prep) 4. It comes with dark tinted windows, does anyone make a clear window set or interior for it or will I have to hand build one? 5. is there a decent prefab roof rack that's known to fit this body? 6. Will the transmission hold up to a geared down 3s? Obviously I don't want fast but I like a nice torquey rig and the only 2s I have are hardcases for my TF2 which wont fit in this. Sorry for all the questions, but I greatly appreciate it! |
10-23-2014, 02:54 PM | #2 |
Quarry Creeper Join Date: Sep 2011 Location: The Swamp
| Re: New to me CC01 Jeep Wrangler
First off......spend a fair amount of time and read...... there are a lot of threads here that will help you greatly. As to your questions.... 1. It is the large square shaped area under the front bumper.... 2. Drive it and see what works and what doesn't work. Then read some more threads in here..... 3. ????? 4. I have seen clear windows on here but don't know where they are from... 5. I would take some measurements and begin searching the web to find one of the appropriate size. 6. These truck are geared way too high from the factory for crawling. Even with a 55 turn brushed motor these should have a Gear reduction unit if you want it to crawl at all. Search the threads here and you will see what others have done. Good luck and remember......we love pics so post plenty |
10-23-2014, 04:01 PM | #3 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
I love my cc01! Easily one of my favorite rigs! I left "the block" on the chassis. I never caught on much anyways. I added a spacer on the front bumper mount to raise it up. I also added spacers ontop of the springs to add more ground clearance. I also clearanced the A arms to allow more droop. don't forget to notch the bottom skid to allow the steering links to droop more as well. see pics below: Sent from my iPhone using Tapatalk |
10-23-2014, 04:32 PM | #4 | |
| Re: New to me CC01 Jeep Wrangler Quote:
2. https://www.youtube.com/results?search_query=cc01+mods 3."Fill" the rear axle with marine grease and also fill the front gears with grease. 4.clear windows there are others out there for cheaper - keep searching 5.roof rack while your at it get this as well rear cargo rack 6.nope. aint going to happen - at least not for long. the internals are all plastic. strippable and breakable. 2s yes - but these things are gears very high! I usually run a 45 turn or higher in this chassis on an xl5 waterproof esc and 9.6 volts nihm pack. Traxxas Ilink rx in a traxxas rx water box and traxxas blue 5065 steering servo. | |
10-27-2014, 08:35 AM | #5 |
3S...lol - no. No need at all in these little rigs.
10-28-2014, 04:25 AM | #6 |
RCC Addict Join Date: Feb 2008 Location: tauranga north island new zealand
My CC01s on 3s, and for a year or so, no problems at all, and a 65t motor.
New to me CC01 Jeep Wrangler - Similar Threads | ||||
Another CC01 Jeep Wrangler YJ XT | the-gamer | Tamiya XC/CC01 | 15 | 04-17-2014 03:45 AM |
CC01 Jeep Wrangler Upgrade | 4j's | Tamiya XC/CC01 | 6 | 07-06-2012 11:29 PM |
cc01 Jeep Wrangler kit any good? | grimgard | Tamiya XC/CC01 | 7 | 10-10-2009 01:03 AM |
