03-25-2010, 10:19 AM | #1 |
Rock Stacker Join Date: Oct 2009 Location: Sumter
| Dig servo BBQ
Chime in if you have cooked a dig servo. just cooked one last night trying to get it adjusted correctly. wasnt paying enough attention to the dig shaft binding and kept adjusting for travel...damn i feel stupid. oh well there goes another 30 bucks.
03-25-2010, 10:40 AM | #2 |
Quarry Creeper Join Date: Oct 2008 Location: Stink Grove
dont feel bad i smoked two till i got it right |
03-25-2010, 11:08 AM | #3 |
Rock Crawler Join Date: Sep 2009 Location: My Old Kentucky Home....
I made the mistake of assembling everything and THEN trying to set EPAs. Fried the first Hitec 225 real quick.
03-25-2010, 11:34 AM | #4 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
Yep it happens. I smoked my 255mg setting the epa's. I learned quickly to set the epa's around 15-20 and start from there. On my setup I think I'm 20 one way and the other about 32ish. I run a home made servo mount like the rcbros, that's the reason for the epa #'s
03-25-2010, 12:29 PM | #5 |
Quarry Creeper Join Date: Dec 2009 Location: Rocklin
I set mine by having it not move and then upping the values till it was right. I am pretty sure that can be done on any remote but maybe not. At any rate you shouldn't fry any servos this way.
03-25-2010, 01:20 PM | #6 |
Yep figured that out a little late...i tore the servo apart and cleared up the solder that melted and it works in one direction now but with very little power. i figured i might as well try since i already got another on the way.
03-25-2010, 04:00 PM | #7 |
Pebble Pounder Join Date: Oct 2009 Location: in a state of labyrinth
I got luckey only stripped the gears. When I powered up with endpoints not set so I think I was luckey a 10dollar fix for new plastic gears. So hope everyone else doesn't have it so bad.
03-25-2010, 04:41 PM | #8 |
ya i fried my 225mg when settin epas so what i did was unsolder the servos board and found an old digital servos board and wired it up and now its digital with no fears of it goin up in smoke
03-25-2010, 07:30 PM | #9 |
Quarry Creeper Join Date: Jan 2010 Location: Dearborn Hts
I haven't cooked one yet but the epa adjustment is so touchy I was wondering if this wouldn't be an ideal place to use a servo saver?
03-26-2010, 04:52 PM | #10 |
Pebble Pounder Join Date: Mar 2010 Location: Danbury
So I got my truck up and running tonight! I have an msx12, and I think that I burnt mine out. It still works but for some reason I can only handle two active possitions even when in 3 way mode on my dx3e. One possition is fully expossing the shaft of the gear. second position pushes that shaft all the way in.... SEriously... then the next possition makes a sound but does not move the shaft any further because it cant move. But its yet to burn out. Any help from anyone? Then nice thing is I can still dig, just front dig. (front wheels move rear do not) Well thanks for the help, Ryan |
03-28-2010, 10:17 AM | #11 |
Rock Crawler Join Date: Sep 2009 Location: In West Monroe,LA...yes,where Duck Dynasty is filmed
Ive burnt 4 hitec 225.Each time i think i have epa set right i burn another one,but hitec keeps sending a replacement(yaaaay Hitec)I finally did the battery tray trick and so far i havent had any problems
03-28-2010, 01:16 PM | #12 |
Just toasted another one this morning. Damn. These things are touchy on EPAs. Was just trying to set them as far out as possible and.....Toast.
