03-03-2011, 12:50 PM | #21 |
Pebble Pounder Join Date: Jun 2010 Location: Ontario,Canada
Is this what I need to program the cc bec? http://www.horizonhobby.com/Products...odID=HPI100573 To run my steering servo at 7.4v and keep the dig servo down at 6v Last edited by Garry; 03-03-2011 at 12:52 PM. |
03-03-2011, 02:24 PM | #22 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
that's it don't know why horizon is so damned expensive on that, look at rpp and they have it cheaper (http://www.rpphobby.com/product_p/csephxl.htm), you'll have to install the software and then just plug the bec into it WITHOUT the battery hooked. then just jockey the power wires on the servo to that and put the servo signal wire to the rx. there is approved castle way as well which is pulling the red from the bec and servo, hooking them together, and having the bec and servo plugged into the rx for the ground.
03-03-2011, 04:32 PM | #23 | |
Pebble Pounder Join Date: Jan 2011 Location: Frisco
http://www.horizonhobby.com/Products...ProdID=CSEPHXL Allowed me and my son to program our BEC's and his MMP. Not sure what the difference is between this and the one you're looking at. Last edited by jwr; 03-03-2011 at 04:39 PM. | |
03-03-2011, 04:58 PM | #24 |
I bought the other one hoping its the only one I have to get for the esc and hopefully the bec, I find it hard to find out all the info on some of these things especially when I know nothing about these bec yet. With my luck though I'll need something else. |
03-03-2011, 05:12 PM | #25 |
naw, you should be good with that programmer, it'll work with all of castles products to my knowledge (edit: all car esc's), and a couple from holmes hobbies as well.
03-03-2011, 05:37 PM | #26 | |
I cant wait to get his crawler going, it should be kick @$$ once he gets use to the dig. | |
03-03-2011, 05:40 PM | #27 |
| The cheaper one allowed us to program a Mamba Max Pro ESC and the 10A BEC's so I'm not sure what the more expensive one does beyond that. Of course I'll probably find out soon when I discover I should have bought the other one. |
03-03-2011, 05:48 PM | #28 |
Thats what I'v learned the hard way with this hobby. So now I try to buy the best so I only buy it once! My first go-round with my LCC I got the Rooster esc/55T combo and a 645mg servo, all good stuff but not for the power hungery LCC.But it worked real well in Dakotas AX10 when we replaced the stock esc in it.Then I went brushless, live and learn. |
03-05-2011, 09:38 AM | #29 |
Quarry Creeper Join Date: Jul 2009 Location: Dublin,Ireland-Cluj,Romania
i have a question,u use DX3E,does your dig unit works corectly in all 3 positions?
03-05-2011, 09:39 AM | #30 |
03-05-2011, 09:42 AM | #31 |
thanks for the info,i'm forward in buying a LCC and i did not know if i can use DX3E,and also thanks for your tips,u have nice rigs |
03-05-2011, 09:45 AM | #32 |
03-12-2011, 04:10 PM | #33 |
| Mamba Max is here! Need Help
I got the ESC installed (its bigger than I thought) and so far its working OK. I used the CLink and got the settings really close to what I want. But I am not sure what to do about the Smatt Sense mode and the Sensored Only mode what is better? I have a MMP and a LRP 17.5 Sensored, 13T pinion on 3S LiPo....the one thing I did notice is under heavy load when I first touch the throtle it will just hum and wont move...why is that? |
03-12-2011, 08:41 PM | #34 |
Heres the stuff we picked up today. Hats off to Castle for making this ESC very easy to program, had no trouble at all everything from the download to changing the settings went smooth and straight forward. These MMP are fairly big compared to my Xcelorin ESC. I wanted to mount it up on the receiver tray but it got in the way the shock adjustment.And I didnt have any lexan to put it on the rear links but he can run it like this for now. Next up we will have to limit the rear shocks and move them out to help with side hilling. It will help clear the ESC too. |
03-13-2011, 02:28 PM | #35 |
Newbie Join Date: Feb 2011 Location: Winnipeg,Manitoba,Canada
is the mmp esc sensor based
03-13-2011, 02:35 PM | #36 |
do the diffs. lose that much greese that you have add a greese port.
03-14-2011, 04:50 PM | #37 |
| Adding the grease ports make it easier to keep the gears in grease all the time, this way you dont have to tare them apart to keep them lubed. Just remove the plug and squirt in the grease. I use a small grease gun that is used for greasing the bar on my chain saw.
03-14-2011, 04:57 PM | #38 |
finally someone coming around to the chainsaw pushluber! looking like you've about got it perfect man, nice work.
03-14-2011, 05:13 PM | #39 |
| Shock limiters and out boarded rears
Tonight Dakota and I installed 15mm shock limiters to the rear shocks and moved them to the outside of the mount. We cut some brake line for the spacer to keep the mount from collapsing. And we also move the tops out a bit to keep them from binding, just used an old shock valve for the top spacer. Now there is lots of room for the MMP. It doesn't get close to the shocks at all now. I need a longer sensor wire, who make the best one out there? |
03-14-2011, 05:35 PM | #40 |
