05-02-2011, 08:24 PM | #21 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
Put in new sets as well. Kind of weird, it bound up untill I installed and tightened all the housing screws. Seems fine now. |
05-05-2011, 02:44 PM | #22 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
I received my replacement gears earlier this week. Installed them with no issue's I've put my Dlux worms back in the box to try these out
05-15-2011, 07:27 PM | #23 |
Quarry Creeper Join Date: Nov 2010 Location: mandan
I put the hd's in the front and had to have no shims on the worm to get the housing to bolt back together, and 1 shim on each side of the spool. spins good, but seems to be binding alittle when running the truck. Do i need to break the gears in longer or are the shims on the spool need to be taken out also?
04-05-2013, 01:53 PM | #24 |
Newbie Join Date: Mar 2013 Location: roma/italia
| Re: HD Worm gear issues...Still??
TraduttoreDa: italiano In: inglese ingleseitalianofranceseRileva lingua italianoinglesespagnolo hi, kindly let me know the following about the gears (Worms HD) by Losi (COMP CRAWLER) .. thank you in advance for your possible answer. a greeting. mark. 1: The (Worm Hd) have fewer teeth (Worm original). Factor this may require more effort on the part of the engine and transmission center in the event of heavy climbs? 2: it is true that the gears (Worms HD), as well havendo 4 teeth less in steep upgrades have the same performance as the standard ones, or even better? 4: globally gears (Worm HD) are better than the originals, in any condition you path? Last edited by marco70; 04-05-2013 at 02:41 PM. |
04-06-2013, 03:52 PM | #25 | |||
| Re: HD Worm gear issues...Still?? Quote:
With the front axle spinning a little faster than the rear the crawler will turn more easily and also climb "steps" much better. You still need to keep them greasy though! | |||
04-06-2013, 05:46 PM | #26 | |
hi, thanks for the reply, I understand (Worms HD front) and (rear Worms STANDARD) a greeting. mark. | |
