01-02-2012, 02:18 PM | #21 |
Quarry Creeper Join Date: Nov 2011 Location: Maryville
| Re: My First Rock Crawler Buildup w/ Losi Night Crawler
I'm thinking about removing the stock battery tray and using 1/4" delrin rod to provide cross brace support instead. Do you think this would help to eliminate some of that unused space and weight? I'm thinking something stronger for the steering, personally. Flex I guess is good for not breaking stuff, but I'd prefer something more accurate. Looks like Amazon.com carries all sorts of delrin, so that's easy enough. Chris |
01-02-2012, 10:55 PM | #22 |
Hey guys, Instead of buying more stuff to make some custom battery trays, move the steering servo, etc, I decided to use what I had from the stock truck. Here's some pics: Here's the trimmed stock battery tray. I figured I could still use the larger 2s 6 cell batteries I have when messing around for longer run times, or use the smaller battery when wanting to compete or just have a more optimal setup. I haven't fully cut the zip ties yet, because I wanted to make sure they were secure enough first. Here's a picture of the re-used piece of battery tray to make the new battery tray. It's a Losi 1650mah 2s Lipo and seems to fit in quite nicely with no binding at full flex either side and only a little rubbing on the bottom side of the receiver at full compression. I also wanted to experiment with the anti-squat, so this is how I first had it setup, which resulted in low anti-squat front and rear, and when climbing a lot of un-needed flex in the rear with lots of binding when approaching the vertical climb. I ended up liking this setup better, which had low anti-squat up front and high anti-squat in the rear. It seemed to bind less when hitting the wall initially, and the flex from front to rear seemed more proportional to each other when climbing. I'll post the little video of the changes in the morning. Chris |
01-02-2012, 11:00 PM | #23 |
Oh, I also removed the rock lights. Tomorrow I'm hoping to solder up the BEC, so I don't have any more initial power-up binding issues and it should be good to go. Chris |
01-03-2012, 01:11 AM | #24 |
Gold Star Baby! Join Date: Jan 2011 Location: SOUTH JORDAN, UT
That aluminum servo mount you were lookin for.... CKRC sells them. I got one for my LCC about a month ago
01-03-2012, 02:24 AM | #25 |
Defy Gravity Join Date: Nov 2009 Location: wells, mn
you're off to a good solid start. only things that really pop out to me are: plastic servo horn, ditch the lowers for something more solid (they will start flexing), and a cheap and easy one is to file or sand the ribs on the skid off, they do hook on things. the battery tray is a thing that i usually tell people to can right away, but you have your reasons there, and watch the drag link. if the drag link starts to flex it is junk, keep the tierod though, pops over obstacles nicely. |
01-03-2012, 05:27 AM | #26 |
Here's a short video after the few mods I did last night: Chris (Ravencr)'s Losi Night Crawler Battery Tray & Anti-Squat Mods - YouTube Thanks for the heads up Redrokin00XJ. I've contacted them to see if they still have some. ghtpdm5, I was just looking at this servo horn: https://www.ckrccrawlers.com/losa990...7da2ae5154cf3c for my 7955 Hitec. I already broke 2 or 3 of the plastic ones. The lowers are being replaced with the bent titanium lowers from DLuxFab. I'll do that on the lower skid plate...thanks for letting me know. Is there a good recommended drag link folks are using that won't flex like stock one? Thanks for the help, Chris |
01-03-2012, 06:05 AM | #27 |
Hey guys, I forgot to ask last night, but how/what parts do I need to turnover my shocks? I tried it last night, but the fittings don't work. Is there a kit available with the proper fittings to flip the shocks and move them outboard, using internal springs for the front? Chris |
01-03-2012, 07:10 AM | #28 |
no need to flip them, its just a way to avoid leaking on the stockers and to inch the cog lower. i used the ball out of a traxxas #1942 rod end to do it, but recently went wide enough with my outboarding to run the stock bits. the drag link, either make your own or a stock lcc one will bolt on.
01-03-2012, 07:20 AM | #29 | |
| Re: My First Rock Crawler Buildup w/ Losi Night Crawler Quote:
If I get a Futaba 4PL for this truck, can I buy another receiver to use on my SC10? If so, will it bind to both vehicles automatically, of course at separate times? Chris | |
01-03-2012, 07:38 AM | #30 |
Hey guys, Sorry for all the questions, but I'm seriously considering getting the transmitter, so I can add dig to my lnc. I also found a complete LCC transmission locally I can snag, but I'm wondering what else I'll need to complete the conversion? Different driveshafts? Dig servo...which one is best? Dig servo mount...which is best? Anything else I'll need? Thanks, Chris |
01-03-2012, 09:12 AM | #31 |
Quarry Creeper Join Date: Nov 2010 Location: Atlantic
Yes you can run the stock drive line , I have it in my LCC. |
01-03-2012, 11:37 AM | #32 |
Did you mean to say I can run the stock lnc drivetrain with the lcc transmission? Chris |
01-03-2012, 12:51 PM | #33 | |
Hey I have a blue aluminum servo horn that came with my Hitec.... Give me your address and I will mail it to ya. No need for money. Payin it forward. Let me know if ya want it. | |
01-03-2012, 12:55 PM | #34 | |
Hahahaha.... I actually have a set of 4 good internal springs that I found at a hardware store here.... I have been runnin these in my LCC for a fewmonths and they work really well..... If ya want I can send those with the servo horn. LMK | |
01-03-2012, 12:57 PM | #35 |
I noticed I have one too, but it looks like I'd need to drill and tap it for the bolt. Is this normal? If so, you don't happen to know what type of bolt is used for the drag link/servo connection do you? 4-40, by chance? Chris |
01-03-2012, 01:00 PM | #36 | |
Chris | |
01-03-2012, 03:22 PM | #37 |
| Re: My First Rock Crawler Buildup w/ Losi Night Crawler |
01-03-2012, 03:55 PM | #38 |
I wonder if that's because the frame for the LCC is different than the LNC? I was told that I needed to run the LCC driveshafts if I'm using the LNC frame... Chris |
01-03-2012, 04:11 PM | #39 |
My build is prob on the second page.
01-03-2012, 05:06 PM | #40 |
as far as I know, the frames are exactly the same. the difference is the transmissions used in each. the lnc shafts will fit fine with the lcc trans. you may need to grind the very end of the ball off a little so they dont bind. I had to with mine.
My First Rock Crawler Buildup w/ Losi Night Crawler - Similar Threads | ||||
New to the Losi Comp Crawler or Losi Night Crawler - Post your questions here! | Mad Dawg | Team Losi Comp Crawler | 355 | 05-14-2023 06:43 PM |
Noob with first crawler ISSUES-> Losi Night Crawler | Javage | Newbie General | 10 | 12-02-2009 10:35 PM |
