Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: Alex's sporty aka The Stormtrooper
Old 03-27-2012, 03:46 PM   #1
Default Alex's sporty aka The Stormtrooper
Got my phoenix chassis in the mail so it's time to open my thread.
I'm gonna build this sporty on the cheap but yet effective with mostly parts I've collecting for my pro.
I think it's gonna be a slow build, hopefully I'll get it running before summer.
Chassis and tranny:
Overkill rc Phoenix with a box stock lnc tranny. I'll run it bodied with an x-citer.
Rear axle:
-Al lockout with homemade weight holder (CDW style)
-Overkill rc shak fin
-Brand new Dlux chromo worm
-Modded shaft and hex for 2mm pin.
-FMJ modd
Front axle:
-HD gear
-Dlux Caster ring
-Lunsford ti kin pin
-V3 cvd's and hex modded for 2mm pin
-Home made front battery/servo plate
-FMJ modd
-BTA steering
-Dlux KW
Wheels:
-Dlux delrin wheel
Shock:
-4" traxxas BB, jeepindoug springcup and shock mount.
Electronic:
-Tekin Fx-r with HH crawlmaster 2012 15t
-Castle BEC 10A
-Hitec HS-7950th
-Futaba 4pl & R203GF rx
Misc:
-Al and Ti hardware.
-Custom lunsford Ti link with traxxas Al hollow ball.
Now two pictures of the chassis with the tranny.
More to come
Alex
AlexG is offline   Reply With Quote
Old 03-27-2012, 07:21 PM   #2
Got Worms?
Default Re: Alex's sporty aka The Stormtrooper
Looks like a good start, how much higher are those outputs on the lnc tranny vs the lcc?
losikid is offline   Reply With Quote
Old 03-28-2012, 07:17 AM   #3
I thought they were at the same height but now that you're asking I think the output are 5mm higher or something like that. I don't have any lcc tranny tough.
Old 03-28-2012, 11:25 AM   #4
Beat you to it :P
yeah it is only a paint job but still
my pink trooper
gyld is offline   Reply With Quote
Old 03-28-2012, 11:57 AM   #5
Never saw a pink stormtrooper mine will be black and white.
Old 03-29-2012, 09:55 AM   #6
Rear axle almost done, I'll do the 2mm pin mod this week end.
Old 03-29-2012, 10:02 AM   #7
Defy Gravity
full fmj with a chromo worm...i am impressed i don't know what kind of beating it would take to do anything to that good work alex!
ghtpdm5 is offline   Reply With Quote
Old 03-29-2012, 12:29 PM   #8
Awsome job!
TheREDCAT is offline   Reply With Quote
Old 03-31-2012, 12:53 PM   #9
And 2mm hex pin never break any so far not even bend one.
Originally Posted by TheREDCAT View Post
Awsome job!
Thanks long way to go before I got a roller
Old 06-04-2012, 06:21 AM   #10
Little progress on my sporty, slow build .
First thing that I've noticed is how much clearance this truck have and I've got plenty of travel without any binding before I start tuning. Good job Overkill RC
The wiring is not done yet I need to calibrate my esc before I ditch the switch.
I still have a few things to do before it runs, rear upper link, bta, wiring and vp hubs for my wheels.
The question is shall I convert my truck to axial hex as axial VP hub are easier to get?
Old 06-04-2012, 10:41 AM   #11
Defy Gravity
go to axial hexes. the cheap cast ones work very well for me, only had 2 stock size pins break in the. the hexes themselves are due for replacement, but they've worked great for the last couple years, even with my beatings.
the more i see the exciter bodies, the more i like them, the white fits them quite well too
Old 06-04-2012, 11:29 AM   #12
Got Worms?
Looks good,
Whats the difference on axial and losi hubs?
Old 06-04-2012, 11:39 AM   #13
Thanks Pete, I'll go axial hex
Originally Posted by losikid View Post
Looks good,
When I first started crawling with my lcc I bought some axial hub with DHs but they caused binding in the drivetrain. Losi hub are flat to fit well the hex.
Old 06-06-2012, 01:50 PM   #14
Not bad for a shafty
Max flex before it binds
Old 06-06-2012, 03:54 PM   #15
Wow looks great!
Old 06-06-2012, 07:12 PM   #16
Got Worms?
Looks great, did you trim the body at all or does it come like that?
Also, i see alot of air between the tranny and skid, is there a way to drop the motor at all? Its amazing how much afew grams means of weight transfer that high up in the air.
Old 06-07-2012, 07:44 AM   #17
Thanks guys
Austin you got me thinking. I've done this mod with a drill and my dremel so it's easy.
I've trimmed the fourth mounting hole and the motor plate.
The motor is sitting 3~4mm lower.
You need to trim the body to your liking, trimmed body would cost more.
There's a lot of unused room on top with a lnc tranny that really make me want to cut a cf phoenix for 3.5'' shock. Lighter, perfect shock travel and a lower body for improved sidehilling. Just an idea in my mind, I may give it a try.
Old 06-07-2012, 09:37 AM   #18
that chassis is sweet!! Where can I get one of those?
iluvny081 is offline   Reply With Quote
Old 06-07-2012, 09:44 AM   #19
Nevermind I found it online. Awesome looking rig! Thanks for posting. I've been lookin for a chassis for my sporty for a while now.
Old 06-07-2012, 09:47 AM   #20
NP give the phoenix a try before they're out of stock.
Alex's sporty aka The Stormtrooper - Similar Threads
Alex's Lomo aka Darth Vader AlexG Team Losi Comp Crawler 369 06-14-2012 08:47 AM
Alex's Axial whitty Axial AX-10 Scorpion 6 08-07-2008 02:57 AM
Stormtrooper Buildinstuff Axial AX-10 Scorpion 13 12-31-2007 07:27 PM
