07-06-2012, 02:03 AM | #1 |
Pebble Pounder Join Date: Jul 2012 Location: Portland
| Clocking The LCC Motor & Tranny-Not The Same Direction Everyone Else Does
I have seen quite a few threads on people clocking the center components 180 degrees, but has anyone clocked them the other direction? As in taking the whole assembly (in stock configuration) and standing it up on one side? You could build some sort of mount so that instead of attaching to the skid plate, it would attach to the side of the chassis. It would give you the ability to take the side to side angle out of the driveshafts so it wouldn't bind on the upper link in front. I searched but didn't see anyone who has done this or documented it.
07-06-2012, 05:59 AM | #2 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
| Re: Clocking The LCC Motor & Tranny-Not The Same Direction Everyone Else Does
If you turn it to its side, your motor will be really high, and give you high cog, or if you do it the other way I think your driveshafts will be to high of an angle. You may want to check out the tranny that BDW is selling, I thinks it's right up your alley!
07-06-2012, 04:09 PM | #3 |
I thought about the cog being too high with that setup. It might work, it might not. I will check into that tranny by BWD (Billet Works Designs).
07-10-2012, 03:07 AM | #4 | |
| Re: Clocking The LCC Motor & Tranny-Not The Same Direction Everyone Else Does Quote:
I couldn't find that tranny you were talking about. Do you happen to have a link for it? | |
07-10-2012, 03:25 AM | #5 |
Quarry Creeper Join Date: Jun 2010 Location: Road Trippin
Pm this guy,billet works. He should be able to hook you up.
07-11-2012, 11:46 PM | #6 |
Thank you. I sent him an email (his PM's are shutoff or disabled).
07-17-2012, 01:26 AM | #7 |
Ok, no reply back yet. So what's next, smoke signals or should I tie a note to a pigeon's foot? Or maybe you can just give me the run down on the tranny? |
07-17-2012, 02:44 AM | #8 |
Rock Stacker Join Date: Oct 2010 Location: Birmingham
I haven't seen the tranny they speak of nor have I heard much about it. Why are you wanting to flip it? That'll put the motor on top of it as well. I think flipping it to get the driveline down the center and if need be, clocking so the motor is towards the front of the crawler is ideal. The tranny still is a little higher than I like, but it's as low as possible for the stock chassis. This is because the driveline is centered making the motor touch the chassis. I noticed a big improvement over stock when I did this though. Try keeping everything as low as possible!! |
07-17-2012, 02:30 PM | #9 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
| Re: Clocking The LCC Motor & Tranny-Not The Same Direction Everyone Else Does |
07-17-2012, 04:20 PM | #10 |
10-4. I checked out his website and didn't see it there either. Maybe I will try the normal flip on mine and see what happens. |
07-17-2012, 04:43 PM | #11 |
Pebble Pounder Join Date: Mar 2011 Location: Aurora, CO
Do a simple offset of the trans. Keep in mind it will make the motor hang out the side of the chassis and will require a bit of work to set up properly. In the end, you gain a lot as far as the ability to run bent lower links and the ability to mount your smaller electronic components lower in the chassis. Marcus |
07-19-2012, 01:47 AM | #12 |
If I do this "simple offset" will it make the crawler lean to the offset side and have adverse handling due to said modification?
07-19-2012, 06:41 AM | #13 | |
Rock Crawler Join Date: Oct 2009 Location: Knoxville
Rubba's TLR Comp Crawler Prototype I just did it last weekend. It is pretty simple, but it takes a while (but I am very slow). It will take some tuning to get used to but I have noticed that everything runs so much smoother, and the ability to run much more bend in the links is fantastic. Also, like dragger stated, all the electronics are so low now. The only thing I have on the chassis other than the dig servo is the RX and BEC (next to nothing, and so low to the chassis). | |
07-19-2012, 04:12 PM | #14 |
Yeah I read that whole thread a while back. Looks easy enough. I've said before I have no problem doing what needs to be done to make this thing perform.
07-21-2012, 07:55 PM | #15 |
Quarry Creeper Join Date: Oct 2011 Location: Shirley
is everyone still running the dig servo on top of the trans? im thinking about trying to tuck mine in beside the trans but not real sure how i would set the linkage up.
07-21-2012, 08:47 PM | #16 |
Pebble Pounder Join Date: Sep 2011 Location: Albuquerque
I am only because I cant find a place that sells one to put it somewhere else. Im too lazy to build one too
07-23-2012, 12:46 PM | #17 |
Here ya go-----> RcBros Hobbies |
07-23-2012, 02:17 PM | #18 | |
07-23-2012, 03:15 PM | #19 |
look on ebay, i found mine used i think they had a couple left., but they wont work with the rubbaneck trans mod. puts the dig servo right where the driveshaft would come out. so i'm thinking of tryin to find a way to put the dig servo in the chassis where rubbaneck had his esc. just gotta come up with a linkage.
07-23-2012, 03:18 PM | #20 |
There is one on eBay right now. I would of posted the link, but I am on my phone. Rubba just runs his dig in the stock location. I did that mod recently and am REALLY impressed. Last edited by dentonmac; 07-23-2012 at 03:20 PM. |
Clocking The LCC Motor & Tranny-Not The Same Direction Everyone Else Does - Similar Threads | ||||
How to do reverse tranny & motor mod? | StickyWheels | Losi Micro-Rock Crawler | 15 | 12-14-2011 07:44 PM |
clocking a motor in a WK tranny and gearing ?? | 72Blazer | General Crawlers | 4 | 03-26-2007 12:16 AM |
Clocking the Tranny????? | Raymond_Q | Tamiya Txt-1 and Juggernaut | 2 | 12-05-2005 02:36 PM |
