03-07-2013, 09:12 AM | #61 | |
Rock Crawler Join Date: May 2011 Location: SoCal
| Re: Nordic Crawler Design Losi 2.2s/Sportsman chassis Quote:
You definately don't want to mount the motor/tranny on the surface of a flat-top skid if you care about CG. Tomi, when you're ready to procede, pocket mill the entire interior down 4mm. Then attempt to place your tranny and you'll see a couple more areas need to be milled down to fit the #3 bolt and also that corner down-bump. It's easy when you see it, but harder to explain with text. Once the tranny fits where you want it you can continue to pocket mill the rest of the skid floor further if you wish. You milled mine nice and deep for light weight. But that was with 8mm skid material. 6mm probably won't take any more milling. Either should work fine. If you want to keep moving forward, but don't have time to work on it, send me a blank 6mm with the rod-end pockets and side-holes installed. My machinist buddy and I will rework it to fit both tranny positions and I'll send you dimensions, sketches, photos and the actual skid if you need it. My thinking is this could be a generic skid undrilled, or you could drill per request for either tranny position. Lastly you could drill all 6 holes and just not use 3. I don't think three unused countersunk holes would hurt anything performance wise. If I were the customer given all those choices, I'd pick the 6-hole. . Last edited by WAM; 03-07-2013 at 09:27 AM. | |
03-07-2013, 12:07 PM | #62 |
| Re: Nordic Crawler Design Losi 2.2s/Sportsman chassis |
03-07-2013, 12:20 PM | #63 |
Rock Crawler Join Date: Feb 2008 Location: Dortmund, Germany
03-07-2013, 12:29 PM | #64 |
Pebble Pounder Join Date: Sep 2010 Location: Australia
Looking good |
03-07-2013, 04:03 PM | #65 |
RCC Addict Join Date: Oct 2008 Location: Finland
| Re: Nordic Crawler Design Losi 2.2s/Sportsman chassis Thanks again for all input and advice. I'll look into it as soon as time allows.
03-07-2013, 11:03 PM | #66 |
03-08-2013, 07:02 AM | #67 |
Next step, link measurement has been done: Greetings Frank |
03-08-2013, 12:57 PM | #68 |
That looks sweet frank |
03-10-2013, 04:42 AM | #69 |
| Re: Nordic Crawler Design Losi 2.2s/Sportsman chassis Thanks a lot Here it is with links and shocks: ...if you want to learn more about it, just have a look here: Dr.Frank's LNC NCD TAG 2.2 Shafty thing Thanks to Tomi, Douwe, Team TAG, YTC and Martin for their help and inspirations Greetings Frank |
03-23-2013, 08:39 PM | #70 |
Got my prototype running. Wasn't planning on doing a build thread, but I'll summarize it with this post. Note this is not quite Tomi's planned production design. This is a SuDu/Losi adaption Tomi built for me to my specifications. It's a bit lower profile, uses shorter shocks, requires lowering the motor/tranny unit to the max and requires centered driveshafts. Tomi, you did a fine job, thanks for working with me. Parts List: DIY XR steering SCX shocks, MRC/silver springs Tekin ROC 3100kv, full sensored, & LNC trans MMP 1-cell, CC bec, Hitec 7950 LCC rear driveshaft, DIY Stampede-based front VP Pro-Comp/SLW wheels with Boss Claws and CI foams Not quite finished but running/comping. As it sits: 4.5 lbs, 60/40. To do list: Link upgrade, steering, D-weights. RTR, Beater body and nice body |
04-21-2013, 10:29 PM | #71 |
Quarry Creeper Join Date: Sep 2010 Location: Perth Australia
Just wondering are there any updates on this chassis as I'm pretty keen to get my hands on one...
06-11-2013, 10:29 AM | #72 |
Quarry Creeper Join Date: Jun 2010 Location: Vienna, Austria
Hello, Are there any news on this? Cheers Daniel |
06-11-2013, 11:22 AM | #73 |
Tomi's taking some time off over the summer. If you don't want to wait, I took some measurements and think an AX Sudu kit could be converted to Losi if you're handy with that sort of thing.
03-02-2014, 08:56 PM | #74 |
Quarry Creeper Join Date: Dec 2013 Location: San Diego county
Deleted
Nordic Crawler Design Losi 2.2s/Sportsman chassis - Similar Threads | ||||
Nordic Crawler Design MOA Chassis Lineup for 2013 | Tomy | Chassis and Suspension | 47 | 06-09-2014 09:35 AM |
Nordic Crawler Design XR10 a.k.a Cannibal | Zarizi Tech | Axial XR10 | 94 | 01-01-2014 10:54 AM |
Nordic Crawler Design Axial XR10 Steering Kit | Tomy | Axles, Trannys, T-case | 64 | 09-17-2013 04:14 AM |
nordic crawler design xr 10 | roxx | Axial XR10 | 76 | 03-10-2013 10:21 AM |
Nordic Crawler Design Brake Rotor for VP Wheels | Tomy | Vendors Tires and wheels | 24 | 11-29-2012 07:37 AM |
