03-21-2013, 03:12 AM | #1 |
Quarry Creeper Join Date: Jun 2004 Location: Melbourne Australia
| Gearbox Ratio?
G'day all. What is the internal gear ratio of the LCC? Want to know what other tranny can be run instead |
03-21-2013, 04:09 AM | #2 |
| Re: Gearbox Ratio?
40:[pinion teeth]
03-21-2013, 04:44 AM | #3 |
| Re: Gearbox Ratio?
Thanks mate. I was hoping just for the gearbox though, with out the pinion spur The B44 buggie has a tranny ratio of 2.6 so it is easy to work out the rest, i was hoping the LOsi would be the same |
03-21-2013, 08:59 AM | #4 | |
Pebble Pounder Join Date: Dec 2011 Location: Ridgecrest, CA
| Re: Gearbox Ratio? Quote:
The LCC trans ratio is 0.87 to 1. Update to the above. After reading Hardline's posts and discussion with WAM, I agree that the trans ratio is about 1.33 to 1. Jerry Last edited by jgrim; 03-25-2013 at 10:40 AM. | |
03-22-2013, 06:22 AM | #5 |
| Re: Gearbox Ratio?
The 40 tooth cog on the output shaft is the spur. (And it can't be substituted!) There is no other ratio to be concerned with since the prior cog wheels just transfer the movement without any change in speed. |
03-22-2013, 02:21 PM | #6 |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
| Re: Gearbox Ratio? You've said that before Olle and you're still wrong. Most people consider the gear in contact with the pinion to be the spur gear. You want to call that an idler and call the next gear (it's 30, not 40) the spur. Okay, let's call it that -- it's reasonable. Call the black plastic gear just an idler. Put a mark on the 30 tooth "spur" gear (on the tranny input shaft) and also on the output shaft and turn by hand. They do not turn 1 to 1. The transmission input shaft spins faster than the output shaft, so there is in fact gear reduction going on.
03-22-2013, 05:45 PM | #7 |
| Re: Gearbox Ratio?
Sweet thanks, that is a pretty piss poor reduction |
03-22-2013, 06:42 PM | #8 |
| Re: Gearbox Ratio? Well that's true, but the reason for it is the Losi's have considerable gear reduction in the axles. So it kinda works out. Personally I prefer lower gearing than that so run the LNC transmission which has much lower gearing. Around 2.3:1 maybe. Creeps great, but wheelspeed is nothing to write home about. The two trannys have identical bolt patterns etc and are interchangeable. You can make an LNC tranny just building up with parts for about $25. |
03-23-2013, 09:12 AM | #9 |
| Re: Gearbox Ratio?
Just for clarification, the LCC trans is actually an overdrive ratio. If you turn the input shaft (the idler gear) one full turn, the output shaft turns approximately 1 1/8 turn. Also note that we normally call the gear in contact with the pinion the spur gear. In this case, it is called the idler gear, consistent with the terminology in the LCC manual. Jerry
03-23-2013, 12:46 PM | #10 | |
I agree with Olle that in this case the large plastic gear is not a participant in the gear ratio. It merely translates motion from the pinion to the metal gear on the input shaft, one tooth at a time to each side. If you were to change it's tooth count, it would have no effect on anything. So ignore it, slip it off and put it in your pocket. The input shaft into the tranny rotates faster than the output shaft from the tranny. That's not overdrive....that's gear reduction. | |
03-23-2013, 01:09 PM | #11 | |
I understand what you are saying, but I was considering that the idler gear is part of the transmission. Rotate the idler gear 1 turn and the output rotates about 1 1/8 turn. Jerry | |
03-23-2013, 01:20 PM | #12 |
| Re: Gearbox Ratio?
Yeah, but you don't want to call the idler part of the transmission at least for ratio purposes. If you substituted a 1000 tooth idler gear, nothing would change. Except your version of the reduction ratio. It makes no sense to base your ratio on a gear that doesn't matter what it's tooth-count is. Kinda by definition "idlers" don't count.
03-23-2013, 09:02 PM | #13 |
Rock Crawler Join Date: May 2011 Location: SoCal
| Re: Gearbox Ratio?
You guys are both right. But I'm going to edit my explanation. It all comes down to definitions. There are three shafts, motor shaft, tranny input shaft and tranny output shaft. Most people would agree the transmission reduction ratio is the input shaft speed divided by output shaft speed. In this case that is about 1.3:1. The difference between the motor shaft and input shaft is generally contolled by pinion/spur, but in this case there's also an idler gear so three gears are involved. The idler has no effect on vehicle speed so essentially the pinion/spur ratio is between the pinion and #3 gear. Olle's "40:pinion teeth" may be mathematically correct but is not the transmission ratio. His answer would be the product of "pinion-spur" x transmission ratio. Like I said, nobody's wrong, we're just all talking in circles. (heh) Last edited by WAM; 03-24-2013 at 09:05 AM. |
03-24-2013, 08:49 PM | #14 | |
RCC Addict Join Date: Nov 2008 Location: I don't think theres rocks in Florida
| Re: Gearbox Ratio?
I had come across this post recently, does it apply? I know the numbers will be lower with hd gears. Quote:
03-25-2013, 03:28 AM | #15 |
| Re: Gearbox Ratio?
The only reasonable way to count (IMO) is "teeth out" to "teeth in". The (40T) "spur" in contact with the pinion doesn't alter the teeth/second speed one bit. Next we have the 30T slipper wheel, which transfer movement to another 30T wheel on the same axle. Again 1:1. Finally we have the 40T wheel on the output shaft, and it is on this wheel the "teeth/second" speed provided by the pinion acts unaltered! It's only when you have wheels of different size mounted on the same axle (and thus turning at the same angular velocity) that there is a change in gearing inside the gearbox. Last edited by Olle P; 03-25-2013 at 03:31 AM. |
03-25-2013, 09:42 AM | #16 | |
You might as well just fit the LNC tranny and gear it to your preference with the pinion. And Olle, give it up. The tranny input shaft and output shaft are rotating at different speeds. There is obviously reduction in the gearbox. I guess not obvious to you. Last edited by Hardline; 03-25-2013 at 09:49 AM. | |
03-25-2013, 07:38 PM | #17 | ||
03-25-2013, 09:22 PM | #18 |
| Re: Gearbox Ratio? |
03-26-2013, 08:13 AM | #19 |
| Re: Gearbox Ratio?
But more importantly it doesn't really matter much. Gearing on any specific car is going to be a tough compromise between acceptable low speed behavior and wheelspeed. You may prefer one over the other, but experimentation with pinions is going to be required to get you where you want to be. We comp our sportys weekly and all of us have gravitated towards pretty low gearing to get the creep behavior we need. None of us are totally happy with wheelspeed. But that's the balance that works best here.
03-27-2013, 03:32 AM | #20 | |
If you scan this subforum for MOA you'll find a heap of threads where the "spur" is a 32-pitch pinion mounted directly on the worm pinion. The motor (one per axle) is mounted right above it. | |
Gearbox Ratio? - Similar Threads | ||||
Noisy gearbox !!???? | threedogs | G-Made Crawlers | 1 | 08-23-2012 07:30 AM |
gear ratio is gear ratio w/trans? | swell searcher | General Crawlers | 4 | 08-16-2008 01:56 PM |
Gearbox ratios? | Jamus | General Crawlers | 16 | 01-14-2006 10:24 PM |
final drive ratio and maxx diff ratio? | mike5721947 | Traxxas Crawlers | 4 | 07-10-2005 01:58 AM |
