Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Team Losi Comp Crawler
Thread: Weight bias and total weight..
Old 11-24-2014, 11:46 AM   #1
Default Weight bias and total weight..
I have made some change to my Losi to shed the max weight I can, and want some knowledgeable opinion!
I now sit at 4-1/4 pounds in running order with the battery.
With a weight ratio of F61/R39.
Should I shed some more weight or change the bias?
SilmarilS is offline   Reply With Quote
Old 11-24-2014, 02:19 PM   #2
WAM
Default Re: Weight bias and total weight..
Trail fun or comp? When I dropped my comp LCC to 4 lbs I started failing at steep obstacles that my buddies could climb. So it's back to 5+ lbs. And back to climbing good.
Light weight is a good thing, but maybe not if it comes at the expense of a higher CG.
60/40 (approx) sounds fine.
WAM is offline   Reply With Quote
Old 11-25-2014, 12:47 AM   #3
Thanks for you input... Just have to make some test. But for now, the weight lost had made it a nimble little machine. The motor just push it way easier!
Old 11-25-2014, 01:10 AM   #4
MODERATOR™
EeePee's Avatar
With all that transmission stuff up in the chassis, the lower bits (axle, wheel, etc) have got to weigh a certain amount to counter that weight for it to handle good. I took 4 ounces out of each wheel. Center of gravity moved way up, truck doesn't handle as good anymore. Nimble, sure but not as capable.
Weight bias is totally dependent on your preferences and terrain. An overall good balanced rig is gonna be better overall than an awkwardly balanced one. Kinda front heavy, but not crazy.
EeePee is offline   Reply With Quote
Weight bias and total weight.. - Similar Threads
Weight Bias The Jackalope Redcat Crawlers 10 04-06-2012 02:28 PM
weight bias bikeboy Axial XR10 1 03-22-2011 07:58 PM
Wheel weight vs. chassis weight ratio OR spung/unsprung bias solomon7 Tires and Wheels 15 08-02-2008 06:26 PM
Weight bias chops1sc General Crawlers 4 06-20-2008 02:13 PM
