Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: 1956 Ford F-100 PTO Winch
Old 03-28-2015, 05:20 PM   #21
Location: in a tree home atop a redwood tree on the corner of yonder and timbuktoo
Default re: 1956 Ford F-100 PTO Winch
I really like your idea for using that diff for a winch!
lil' bear 4wd is offline   Reply With Quote
Old 03-28-2015, 06:44 PM   #22
Originally Posted by josh6575 View Post
The ends of the axles are shaved off for collars to have clockable c-hubs. Everything else is stock. The comp crawler would steer pretty good out of the box. Just needed clocked a little. I tried the Dlux versions and broke them. Made a couple out of aluminum.
Have any other pics of this? I have two axles that need this treatment.
Menace Kustoms is offline   Reply With Quote
Old 03-28-2015, 09:51 PM   #23
Hey Josh I am sure I have a new unpainted body 56 Ford if you need another.
paintchip31 is offline   Reply With Quote
Old 03-29-2015, 05:41 AM   #24
Menace Kustoms
Here is the original thread.
LCC infinite caster adapters (Incredible Hulksta mounts)
I believe he still sells the collars. I also think there is an updated version that is thicker at the c-hub screws and will not break as easily as the ones in the pics. Check here.
DLUX FAB | products
josh6575 is offline   Reply With Quote
Old 03-29-2015, 05:46 AM   #25
Paintchip31,
I am digging my beat up body. Only thing I don't like is the body mount holes. I was thinking about attaching two small hood scoops to cover them. A new body means I have to paint. The only thing I like about painting is the funny feeling I get while spraying in an unvented area.
Old 03-29-2015, 07:13 AM   #26
Well I have it over here if you change your mind! Plus I have airbrush you can make it look any way you want!!
Old 03-29-2015, 10:53 AM   #27
After looking through my bag of spare Losi parts. I found that I had a pair of the infinite caster adaptors.
Old 03-31-2015, 02:14 PM   #28
Tired of messing with the winch for a moment so I built a bed out of craft sticks, CA glue, and lots of paint.
Old 03-31-2015, 02:20 PM   #29
I dug through my box o junk and found some Du-bro airplane control surface hinges to use on the tail gate. Glued them on.
Old 04-01-2015, 07:08 PM   #30
Mounted the bed, tailgate, and truck box today.
Old 04-04-2015, 09:51 AM   #31
Just about got the winch mounts done.
Old 04-04-2015, 10:44 AM   #32
This is one of the most unique builds I've seen in a long time. Lovin' it!
Super is offline   Reply With Quote
Old 04-05-2015, 06:26 AM   #33
Thanks for the compliment super.
Old 04-10-2015, 02:16 PM   #34
Turned a spool and attached it with a flat on the shaft, set screw, and blue Loctite. Used some 50# test braided fishing line. Drilled three holes in the side to retain the line instead of tying knots.
Old 04-10-2015, 02:20 PM   #35
Used a Viking fairlead from RC4WD. Drilled through the bumper and put in some 5mm shoulder bolts. Chopped them off and ground flats on them to flush mount the fairlead. Drilled and tapped 2mm for the attachment. Looks a little goofy from the offset. I just wanted to center it up with the spool to make sure it worked well. Function before form around here. Or I am just lazy.
Old 04-10-2015, 02:21 PM   #36
Here it is with the lid in place. Stuck some Velcro on the shift servo and underside of the hood.
Old 04-10-2015, 02:58 PM   #37
Here is a short video of the winch in action. I must have had a knick in the line. Never had this stuff break easily. I usually straighten hooks with it.
Old 04-10-2015, 03:23 PM   #38
This video is a little better.
Old 04-10-2015, 08:21 PM   #39
That is sweet! Does it also free spool?
Old 04-12-2015, 11:23 AM   #40
As soon as the trans is disengaged for driving it is in free spool.
I ran it at a Guru comp yesterday. Found that I to find something better than the novak 21.5 to run it. Not nearly enough guts.
Also matching the wheel speed to the winch speed is not a good idea. It was lifting the rear end of the truck while cresting the top of a rock in my yard. More work to do for sure.
1956 Ford F-100 PTO Winch - Similar Threads
PTO Winch with Slipper Clutch sweli Scale Videos! 10 06-15-2013 07:34 AM
'Old Blue' 1956 F-100 Truck-4TEN-Build on 1.55s Generis 1.5 Scale Rigs 28 04-22-2013 08:32 AM
PTO Winch w/Rolling Fairlead sweli Scale Videos! 10 03-29-2011 01:06 PM
PTO Winch w/Rolling Fairlead sweli Scale Accessories 37 03-24-2011 04:36 AM
