11-30-2015, 09:29 AM | #21 |
Rock Stacker Join Date: Mar 2015 Location: Houston
| Re: Losi Night Crawler 2.0 help! |
11-30-2015, 03:38 PM | #22 |
Rock Crawler Join Date: Sep 2011 Location: Richfield
All of the above is true^^^^^ And I would still install a Castle BEC. |
12-02-2015, 08:36 PM | #23 |
Newbie Join Date: Dec 2015 Location: in a house
I vote esc... received my new 2.0 today and it was dead on arrival. At least horizon had no issue sending me a new one out the same day!
12-04-2015, 01:45 PM | #24 |
Newbie Join Date: Nov 2015 Location: Ogden
Well I have come to the conclusion that I have a bad motor. I tore the axles apart and heavily greased them and put them back together and ran for about 5 minutes before it started to stall again. I have a Venom LVM (Low Voltage Monitor) that I put on the battery and monitored the voltages live and the voltages came no where near the cut off point so I think that eliminates the ESC as a problem. I also closely monitored the ESC and watched for it to blink giving me a low voltage warning and it never did. I was just crawling around the house cause there is too much snow outside and was crawling up the side of a couple of cardboard boxes and it would stall out and I noticed a little bit of smoke when it stalled out so I picked it up and it looked and smelled like it was coming from the motor. So I think I need to get a new motor and while I am at it I will just get a better ESC too. So on that note, what do you guys recommend?? Brushed or brushless?? Thanks for all of your help and input everyone, I appreciate it!! |
12-04-2015, 03:07 PM | #25 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
MMP + brushless motor. To many options on motors so you can decide that. Figure out what you want to spend and how fast you want it to go.
12-04-2015, 03:44 PM | #26 |
Rock Stacker Join Date: Oct 2015 Location: NKY
Definitely sensored brushless.
12-05-2015, 01:46 PM | #27 |
Ok cool! Can the stock worm gears handle brushless motors ok?? And I have been looking at the Tekin ROC412 brushless crawling motor, does anyone have any experience with this motor?? And is the MMP ESC waterproof?? I can't see that it says anywhere on their site. Thanks!
12-05-2015, 01:51 PM | #28 |
Also looking at the Novak Ballistic crawler motor, any input on this??
12-05-2015, 02:27 PM | #29 |
Yes worms will handle it no problem. But plastic tranny gears and front pins in axle shafts are the 2 things you may have trouble with depending on the motor kv, pinion and what cell battery you'll run. Both of those motors are very good choices for the losi (I run mmp/roc412 3100kv/3s in mine). You can get the mmp and roc waterproofed from holmes.
12-05-2015, 05:11 PM | #30 |
I just installed this: HOBBYWING TECHNOLOGY CO., LTD. and this: (13.5t) HOBBYWING TECHNOLOGY CO., LTD. and am running the HD worms with a 14t pinion and I'm very happy - got the esc/motor/programming box as a package deal off of eBay for pretty cheap - my build is a "budget" build and, if money was not an issue, I'd have probably gone with the MMP, but the hobbywing setup is very smooth in the lowest of RPM ranges and flat out boogies when I floor the throttle - I run it on a 3 cell, 2200mah, 20-30c turnigy lipo and the motor is around 140 degrees after the battery is done - I've got 15 and 16 tooth pinions on the way and will also be playing with the timing on the esc for even more wheel speed The build is intended as a crawler/trail truck hybrid that I built to accompany me on hiking trips through the woods - many will suggest a 17.5t or 21.5t motor, as they are more "crawler" oriented motors, but I wanted my slow Losi to entertain me on flat ground between obstacles and I am very happy that I chose the higher kv motor - like I said, it crawls very smoothly and, when I ask for it, absolutely rips up and over obstacles and climbs…and it easily and quickly goes from super low RPMs to full speed instantly Also, I think hobbywing offers the esc in waterproof - the motor has vents in the can, so I don't think it would appreciate being TOO wet none too much - but I certainly don't have any reservations about it handling some moisture…but while I plan on running it through wet grass, shallow water (1-2"), and shallow mud (the type encountered on the surface of moist soil, not soupy mud bogs that are mostly water), I won't be running it submerged in liquid My LNC used to bore me so much that I never ran it (because of the lame sauce speed and having the majority of my RC interests in high speed, high voltage monster trucks), but with this brushless setup, the quicker HD worms, and larger rover ex tires, this thing is a blast to drive now! - it pulls small wheelies, spins the tires/throws dirt around, hauls a$$ between obstacles, and crawls powerfully mudholestomper |
12-05-2015, 05:26 PM | #31 | |
| Re: Losi Night Crawler 2.0 help! Quote:
I ran my stock nc motor on 3 cell lipos using a cheap, no-name esc forever and it held up well - but I think I just got lucky - it's far from a great design and, while usually durable with reasonable use, is pretty much a typical throwaway RTR type part go sensored brushless, go 3 cell lipo, don't get anything less than a 2500kv sensored motor (540 size works just fine), and you'll really start enjoying that truck much more than you did in stock form Don't forget to look through the thread regarding reducing the friction on the whole vehicle mudholestomper | |
12-05-2015, 09:11 PM | #32 |
Yeah I think that I will go with the Tekin ROC412 3100Kv motor and the MMP ESC . With the 3100Kv motor do you think I should go down to a smaller pinion from the stock?? I am not really look for speed, but if I can get some more speed out of it and still have it be an incredible crawler I am all for it!! If I feel the need for speed I will break out my HPI E-Firestorm Flux lol |
12-05-2015, 09:57 PM | #33 |
I will also be upgrading the steering servo soon. And that brings up another question......will the BEC in the MMP be enough or will I still need to get a separate BEC??
12-05-2015, 10:15 PM | #34 |
Newbie Join Date: Apr 2014 Location: Adelaide
I use a separate BEC on my LNC. Figure it is cheaper to kill a separate BEC rather than the MMP.
01-01-2016, 04:14 PM | #35 |
RCC Addict Join Date: May 2011 Location: at home
you use a bec to be able to provide higher voltages to the servo look at the specs of the servo and you will see that with a higher voltage you get more torque. typically the built in becs in the escs are set to 5 volts the better servos can use 7 volts or more |
01-01-2016, 04:32 PM | #36 |
Quarry Creeper Join Date: Aug 2013 Location: Wijnandsrade, NL
I recently installed a Hobbywing sensored combo 17,5T in my LNC and love it! The smoothness is has.... Awesome! Asiatees even has a 10% discount at this moment. And yes, a Bec should be mandatory... . Check HeyOk here in Vendors. He has a NoBrainer, works flawless! Hobbywing Hobbywing QuicRun Sensored Brushless System: WP-10BL60 ESC+3650-17.5T Motor Combo For 1/10 & 1/12 RC Red HW/QUICRUN-10BL60+3650SD17.5T |
01-01-2016, 09:43 PM | #37 | |
Pebble Pounder Join Date: Apr 2015 Location: canada
Losi Night Crawler 2.0 help! - Similar Threads | ||||
New to the Losi Comp Crawler or Losi Night Crawler - Post your questions here! | Mad Dawg | Team Losi Comp Crawler | 355 | 05-14-2023 06:43 PM |
