12-05-2015, 05:10 PM | #1 |
Newbie Join Date: Dec 2015 Location: Irvington
| Expected run time for LNC with 5000mah Lipo
Looking to upgrade my battery from a 3000mah nimh. Around how much run time would I get with a 5000mah lipo?
12-05-2015, 07:20 PM | #2 |
Rock Stacker Join Date: Mar 2015 Location: Houston
| Re: Expected run time for LNC with 5000mah Lipo
2 cell or 3 cell The only insight I can give you is, when my LNC was completely stock except for a no-name, Chinese brushed esc, I only ran it using a 2200mah, 3 cell, 20-30c turnigy battery and it would run so long I'd lose interest after 30-45 minutes I'd remove the battery and test each cell with a decent quality multimeter at the balance plug and each cell would still have 3.6 - 3.8 volts - I didn't have the means to test the remaining capacity, but given the voltage readings, I (and I'm making an assumption here) feel I could have crawled around for at least another 30-45 minutes before the voltage got down near 3 volts/cell or 9 volts for the whole pack based on my (rudimentary) understanding of the relationship between voltage, mah ratings, and C ratings, given equal ratings for a 2 cell and 3 cell, the 3 cell will far outlast a 2 cell under the same loads - if the mah and C ratings are identical for each battery, the 3 cell's higher voltage will allow it to drain slower - a 5000mah pack with a 30c rating can output 150amps maximum - but the 3 cell pack will need to deliver the 150 amps less often to achieve the RPMs from the motor than the 2 cell pack, thus the 3 cell pack will not slurp as much at the battery's capacity (mah) I could be a bit off on that analysis, so if someone wants to correct it, please do! - and my analysis is pretty rough and does not take into account all of the other things that play a big role in run time, including (but not limited to) wire size/type, connectors used, esc and motor, vehicle weight, gearing, tire size, and friction related stuff mudholestomper |
12-14-2015, 12:57 AM | #3 |
Mudholestomper got it about right. My angle is that a smaller (read: lighter) battery will give you better crawling performance. 5000mAh is only good for trail runs where you don't need the obstacle crossing. 3S is out of question with the stock electronics. A 2S 5000mAh battery should provide about twice your current run time, more if your current battery is actually well below 3000mAh. ~1500 mAh will give you half an hour of intense crawling, and then the worm drives should be allowed to cool down anyway. |
Expected run time for LNC with 5000mah Lipo - Similar Threads | ||||
LNC Run Time | olsenjb | Team Losi Comp Crawler | 15 | 05-26-2015 09:39 PM |
Can an HBX "Rockfighter" Rock crawler esc run safely on 5000mah 2s lipo? | warmanjames | Electronics | 1 | 12-15-2012 06:54 AM |
35t motor+5000mah 3s=??run time?? | muddinscx | Electronics | 9 | 09-11-2011 05:18 PM |
lipo run time | spgrading | Electronics | 2 | 12-27-2009 09:56 PM |
nimh vs. lipo run time | jwilli2213 | Newbie General | 18 | 12-09-2007 08:13 PM |
