01-06-2012, 03:55 PM | #421 | |
Rock Crawler Join Date: Sep 2009 Location: Orangevale
| Re: **New** DLUX Wheels Quote:
I run 725s in the rear and 475s up front it's 10.5 up front and 10.25 in the rear out side of tire not true trac width from out side of wheel to out side of wheel. it works really well like that I still get all my steering and it is still stable. | |
01-06-2012, 05:43 PM | #422 |
Pebble Pounder Join Date: Sep 2011 Location: Saskatoon
| Re: **New** DLUX Wheels What width are you running your wheels up front? And are you using stock or VP steering knuckles?
01-06-2012, 06:08 PM | #423 |
| Re: **New** DLUX Wheels |
01-06-2012, 06:49 PM | #424 |
Ah ok that's probably how you got clearance with the smaller hubs, I did my mockup with 1" wheels, i do have a pair of .7" as well. Not sure which i'll like better yet.
01-06-2012, 07:51 PM | #425 |
| Re: **New** DLUX Wheels I like the .7 but I all so run a narrowed tire, but with the delux wheels the options are endless. Good luck
01-06-2012, 09:06 PM | #426 |
I am thinking a .900 wheel could be perfect on the xr for this reason. That is, if you're willing to go narrower than 1"
01-07-2012, 11:47 AM | #427 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Thought I would share a way to add weight to the new 1.9 wheels. It was a simple stop at the hardware store and about 15.00 I picked up some collars from hi strength nut and bolt. They are 3/4". I needed to open up the Id a bit so out came the uni bit.It steps cuts obviosly but that was a plus since these are slipping over the SLW hubs and they are tapered. Installed over SLW,just a press fit and then use the supplied set screw to lock them down.The set screw will fit right inbetween the ribs on the SLW hubs. Installed on wheels I also picked up some 7/8 split collars to use.They are bit big in the od and need to be turned down when I get the chance.These will weigh a bit more and give me another tunning option.The Id is perfect and no step drill will be needed. I also picked up some really thick washers to use in the rear wheels. I didnt snap any pics but the step drill came out again and a press fit was in order. |
01-07-2012, 12:06 PM | #428 |
RCC Addict Join Date: Jan 2010 Location: Lafayette
Ordered late Thursday and they got here Saturday. Awesome turnaround Erik!
01-08-2012, 09:50 AM | #429 |
Rock Crawler Join Date: Sep 2009 Location: The BYB Compound
Thanks to Erik these wheels have endless options to choose from. We have a guy in the group that likes to run .7 wheels with narrowed tires to get the track width as narrow as possible. We also have a guy in the group that has problems with getting stuck in holes. So what he did was this. He took a couple sets of sedonas cut them up and made a set of 2.5 inch wide tires. With how wide the tire was a 1 inch wheel jusst wasnt enough. So i called Erik and asked for a 1.5 inch spacer to make his wheel wider to fit these tires. Here are a few pics to show this. The third pic is the wide wheel and tire next to a stock sedona on a 1inch wheel and the 4th pic is the wide wheel and tire next to a narrowed set of sedona/boss claw on .7 wheels. Thanks again erik for the superb products.
01-08-2012, 12:09 PM | #430 |
That's great info Geo and another great thing about the wheels is because of the way the hub bolts to the wheel face you can run a wider tire and not make your track with wider the extra wide sadonas did not make the track width any wider just pushed the wheel closer to the shock. That's my dads rig and he seems to be liking it so far. Thanks for the great parts and awesome customer service. |
01-22-2012, 09:06 PM | #431 |
I wanna be Dave Join Date: Sep 2009 Location: Eastcoast CANADA
Here is a pic of Tgreers tractor wheel skins....
01-22-2012, 09:09 PM | #432 |
Pebble Pounder Join Date: Jun 2005 Location: west depford
the skins look killer
01-22-2012, 11:00 PM | #433 |
That tractor turned out sick!
01-23-2012, 08:32 AM | #434 |
01-23-2012, 08:49 PM | #435 |
Some new stock wheel skins...
01-23-2012, 11:39 PM | #436 |
RCC Addict Join Date: Jan 2007 Location: Bouldertown
Nice stuff. Too bad they would t work on the outside. Don't have clear discs.
01-26-2012, 10:24 AM | #437 |
Rock Crawler Join Date: Oct 2007 Location: south of France
| Re: **New** DLUX Wheels I love these wheels !!! (I know the weight rub inside the wheels, need to shim the shaft) |
01-26-2012, 10:31 AM | #438 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
| Re: **New** DLUX Wheels Thanks Eric! With your new wheels and berg goodies cutting a pound out of my rig, and the killer skins from krawler koncepts, this rig should turn a few heads and do me well this season. Your wheels are fantastic, I love the adjustability! |
01-27-2012, 10:19 PM | #439 |
RCC Addict Join Date: Feb 2008 Location: Winnipeg
Made an order earlier today and just got a shipping notice not to long ago. Now that's service! Can't wait to try these on my XR
02-07-2012, 10:49 PM | #440 |
Newbie Join Date: Nov 2010 Location: Atlanta
What spacers are u guys running on the 1.9s just trying to figure out what to order
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/tires-wheels/344184-%2A%2Anew%2A%2A-dlux-wheels.html | ||||
Highlucks - Team BWD - The Thing - Team Adrenaline Forums | This thread | Refback | 03-01-2013 07:05 PM |
