01-13-2012, 01:37 PM | #1 |
Quarry Creeper Join Date: Apr 2010 Location: The basement of the science building.
| Wheel Air Holes
How many and what size air holes are you drilling in your wheels? I have 4 Vanquish SLW3 1" wheels that need breathing holes and can't decide if they should breath slowly or rapidly. I will be using Vanquish 5120 foams with the triangles removed. The crawler is a Beetlejuice V1 Berg.
01-13-2012, 01:42 PM | #2 |
RCC Addict Join Date: Jan 2010 Location: Barboursville, WV
| Re: Wheel Air Holes search "breather" in this forum and you get more than one page of results. The general consensus is 1/8" hole...still up in the air is how many - ranges from 1 to 4 or more. |
01-13-2012, 01:48 PM | #3 |
I wanna be Dave Join Date: Feb 2009 Location: Cowtown, USA
| Re: Wheel Air Holes |
01-13-2012, 02:25 PM | #4 |
Quarry Creeper Join Date: Feb 2011 Location: Wellford, SC
| Re: Wheel Air Holes
I had trouble making myself drill holes in my expensive VP wheels so I cut small holes, 2 about 1/16" dia. with my wire cutters, in the tires instead and it was a very nice option. Works really well, you can't even notice them unless you look for them and tires are a perishable item, my wheels are not. Just my $.02.
01-13-2012, 02:42 PM | #5 |
Rock Crawler Join Date: Oct 2011 Location: Corona, CA
| Re: Wheel Air Holes
I have always contemplated holes, but can never bring myself to do it. The sound of getting sand, dirt, water inside and tearing up the foams I don't like I guess
01-13-2012, 02:45 PM | #6 |
| Re: Wheel Air Holes
I've taken my tires off many times and have never found anything inside my tire. Hard to imagine anything getting in there with the foams pressed hard against the tire. But I understand it's possible, I guess.
01-13-2012, 03:20 PM | #7 |
| Re: Wheel Air Holes
That does make sense Can you get a pic of your wire cutter hole, or is it actually just a slice than a hole? I would actually try that option on my rig |
01-13-2012, 04:44 PM | #8 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
| Re: Wheel Air Holes
4 1/8" holes in each wheel..............
01-13-2012, 05:02 PM | #9 |
| Re: Wheel Air Holes
If you dont have big enough holes or not enough holes , you will get some bounce....... if you squeeze your tire on only one side as hard an as fast as you can while watching the other side, and if you see the other side get bigger then you dont have enough holes.... (or not big enough) if the air cant escape fast, you will get bounce.......... hope that makes sence.......... well at least, this works for me............ |
01-13-2012, 05:29 PM | #10 |
| Re: Wheel Air Holes I never have any luck searching on any forum but I did this time! I'd have used every other word but "breather". I'm a dumbass so thanks for the search word suggestion...seriously! |
01-16-2012, 04:23 PM | #11 |
Quarry Creeper Join Date: May 2008 Location: Out in the country
| Re: Wheel Air Holes
I agree with Strato54, cut your holes in your tires NOT your wheels. Just my opinion. I have tried both, but like the tire holes better than wheel holes. Good luck. |
01-16-2012, 04:32 PM | #12 | |
Quarry Creeper Join Date: Oct 2011 Location: Georgetown, On
| Re: Wheel Air Holes Quote:
01-16-2012, 07:03 PM | #13 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
| Re: Wheel Air Holes
Well you can use a leather punch for making holes in tires and if you are good than you could drill a hole in the rim to intersect a beadlock ring screw so that you can plug it if you want |
01-16-2012, 07:11 PM | #14 |
01-18-2012, 04:57 PM | #15 |
Quarry Creeper Join Date: Feb 2005 Location: Australia
| Re: Wheel Air Holes
I use a soldering iron and put two holes in each tire (180 degrees apart). The soldering iron seals the hole and seems to stop it from ripping further. For the same reason, I can't bring myself to drill into my expensive VP wheels. |
01-20-2012, 12:57 PM | #16 |
Newbie Join Date: Oct 2011 Location: L.A.
| Re: Wheel Air Holes
I drilled some small breathers 180 from each other, but far out enough on the wheel so I can plug them with a cap head screw so the foams don't soak/degrade if I come across some water, or when its time for a good scrubbing.
01-20-2012, 04:04 PM | #17 |
RCC Addict Join Date: May 2009 Location: In the warmth!
| Re: Wheel Air Holes
I usually drill and tap two 3mm holes. Need less; put in a grub screw. Need more; drill 2 more. |
01-20-2012, 04:20 PM | #18 |
Rock Stacker Join Date: Dec 2011 Location: Atlanta
| Re: Wheel Air Holes
i normally drill a 1/8 hole in each wheel, been fine for me
01-20-2012, 04:56 PM | #19 |
Newbie Join Date: Dec 2011 Location: va beach
| Re: Wheel Air Holes
i cut 3 small slits in the backside of my tires. It seems to be working fine.
01-20-2012, 07:42 PM | #20 |
Pebble Pounder Join Date: Aug 2011 Location: dayton.tn
| Re: Wheel Air Holes
a 1/8in hole in each tire should work good |
Wheel Air Holes - Similar Threads | ||||
Looking for the Robby Gordon wheel 6 "D" holes non beadlock plastic | toy4crawlin | General Crawlers | 3 | 12-02-2009 09:54 AM |
Putting holes in tire (for air) | Spiftacu1ar | Newbie General | 9 | 09-13-2009 07:11 PM |
no air holes? | m3kan1k | Tires and Wheels | 1 | 12-31-2008 12:24 AM |
