12-29-2012, 03:19 PM | #1 |
Newbie Join Date: Aug 2012 Location: Salisbury
| Removing screws from rim
I have Vanquish wheels and I cannot remove the screws from the rim, they are so tight that I end up stripping the screw's head. How can I unscrew these things? The tire is coming out and needs to be tucked back in. |
12-29-2012, 04:35 PM | #2 |
Rock Crawler Join Date: Jan 2007 Location: West Seneca
| Re: Removing screws from rim
if they are stripped i usually take a dremal with a cut off wheel and cut a grove in it and just use a flat head screw driver, make sure you either cut it right or use correct sized flat head so it fits snug should come right now then
12-29-2012, 04:55 PM | #3 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
you can also try to center drill it and use an easy out. I've had to do that before, just make sure you have the easy out seated solidly before attempting to extract the screw
12-30-2012, 07:18 AM | #4 |
Rock Crawler Join Date: Sep 2011 Location: Stanford
X2 on what mindless said |
12-30-2012, 08:58 AM | #5 |
Quarry Creeper Join Date: Jan 2009 Location: B-E-A-utiful Vancouver Island
also I find that if u put a little heat or penitrating lube on it, it will help losen up the corrosion of the 2 dissimilar metals. I find that after awhile any SS or oxide screw used in aluminum tends to oxidide/corrode and become "stuck"
12-30-2012, 12:49 PM | #6 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
What allen driver are you using ? A good quality set will fit better and have less chance of stripping the heads. If they are 2mm, try the MIP 5/64 driver. It is numerically the same size but always seems to remove the tight and or stripped screws for me. |
Removing screws from rim - Similar Threads | ||||
binder screws vs standard screws for plastic | Meatwad | Tools, and Procedures | 9 | 10-03-2019 01:20 PM |
what size screws are spur screws? | STANG KILLA SS | General Crawlers | 3 | 10-09-2009 07:24 PM |
Came with shattered rim? In need of 1 stock rim... | Smash N Bash | General Crawlers | 13 | 06-25-2006 09:07 PM |
