03-16-2013, 05:25 PM | #1 |
Pebble Pounder Join Date: Jun 2012 Location: Lucerne Valley
| Wheel weights and the foam
Added the stick on wheel weights to the Axail 1.9 beadlocks and the tire doesn't feel to flex as well. Do you guys trim the foam any when you add weights to them? Thanks J. |
03-16-2013, 06:43 PM | #2 |
Pebble Pounder Join Date: Sep 2010 Location: Hopewell, Pa
| Re: Wheel weights and the foam
I've never trimmed any of my foams an I always run the stick on wheel weights. What foams are you using?
03-16-2013, 07:23 PM | #3 |
Stock foam and Rip Saw tires on a Honcho.
03-16-2013, 09:29 PM | #4 |
Quarry Creeper Join Date: Oct 2010 Location: Hendersonville
I'm running 1.9 PBs on Axial beadlocks. I bought stick on weights but haven't installed them yet. Any suggestions on how much to add front and rear?
03-17-2013, 12:16 AM | #5 |
From what I read out of searching around 4 oz. for the front and 3 oz. for the rear, its a starting point im trying out in the morning...
03-17-2013, 01:33 AM | #6 |
Newbie Join Date: Jan 2013 Location: 808
| Re: Wheel weights and the foam i just put 2.5 oz of stick on weights on my axial beadlocks and PB's with stock foam. The added size of the wheel with the weights helped stiffen up the inner foam a little bit and it feels much better IMHO.
03-17-2013, 01:50 AM | #7 |
Newbie Join Date: May 2011 Location: rome
don't worry is normal the weights press the foam, now depend only how much is heavier your truck I like my tyres a little deflated so I trim the foam you can chose or trim inside just the space keeped by the weights or outside with classic star cut |
03-17-2013, 10:14 PM | #8 |
The weights in the wheels made a huge difference .. The tires flexed pretty good still might trim the inners or do a small star cut outs.
Wheel weights and the foam - Similar Threads | ||||
pro's con's Wheel weights and foam trimiming | systema | Superclass Crawlers | 4 | 04-09-2012 11:41 AM |
Knuckle Weights vs. Wheel Weights | Harvo | Tires and Wheels | 34 | 11-16-2011 01:15 PM |
Trimming foam to fit wheel weights? | 0lllllll0 | Tires and Wheels | 17 | 03-08-2011 10:12 PM |
Function of weights, water, lead, and foam? | PipeDreams | Tires and Wheels | 27 | 04-10-2008 02:56 PM |
Mashers:weights,bb's, foam or combo? | solomon7 | Newbie General | 5 | 08-18-2007 02:57 PM |
