04-04-2014, 11:48 AM | #1 |
| Testing Interest: Made to order wheels
I'm kicking around the idea of offering made to order, custom offset/width 1.9 & 2.2 delrin wheels. They will not include rings or hubs...just a set of wheels built to your specs. They will be drilled to accept easily sourced VP/Shifts/etc slw bolt pattern and Axial compatible beadlock rings (holes drilled and tapped to your specs). Actual designs will vary, but kept simple to keep the prices low. Widths could range from 1/2" to 3", and any offset you want within the width of the wheel. A sample (shown with MThead beadlock ring): I have a price range in mind, but would like to hear everyones thoughts on the matter... |
04-04-2014, 02:55 PM | #2 |
RCC Addict Join Date: Aug 2007 Location: Seattle
| Re: Testing Interest: Made to order wheels
I'm interested in any blems you might end up with. The cost of rims has gone down but they're still out of my price range. *I'd really like a 1" 1.9 that will handle abuse. Planning on runing a 8.5t on 3s. Last edited by djjiz; 04-04-2014 at 03:53 PM. |
04-04-2014, 03:59 PM | #3 |
RCC Addict Join Date: Apr 2011 Location: San Diego
Interested =)
04-04-2014, 04:10 PM | #4 |
Quarry Creeper Join Date: Sep 2011 Location: Lexington
Are mine done yet?
04-04-2014, 05:18 PM | #5 |
Newbie Join Date: Dec 2012 Location: fryburge
im interested if you im tring to find stock chevy rally wheels in 1.9 or 1.55
04-04-2014, 05:31 PM | #6 |
Rock Crawler Join Date: Mar 2014 Location: Yorkville
id be interested in some wider 2.2's for my bouncer.
04-04-2014, 06:14 PM | #7 | ||
| Re: Testing Interest: Made to order wheels Quote:
It would also be ideal for those doing custom builds that need a narrower or wider wheel than they would usually find. Obviously I could do more complex designs, but at a greater cost. Since they are made to order, the hub area could be thickened up if you want more strength and wouldn't cost any more. Quote:
How wide? | ||
04-04-2014, 06:20 PM | #8 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
interested ... |
04-04-2014, 09:37 PM | #9 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
I'm interested for sure. Deep dish 1.9 that looks like a steel d-window with slw compatibility. |
04-04-2014, 09:46 PM | #10 |
Could I get a wheel that glues on the hub side but has a beadlock face? I think it would help with foam tuning and this way we could get more room for maximum knuckle weights.
04-04-2014, 09:50 PM | #11 |
| Re: Testing Interest: Made to order wheels Keep in mind that I do not have a cnc machine...everything I do is done manually. A d-window wheel would be very time consuming, and not cheap. They could be made though...
04-04-2014, 09:52 PM | #12 |
| Re: Testing Interest: Made to order wheels |
04-04-2014, 09:52 PM | #13 |
Rock Crawler Join Date: May 2012 Location: Columbus
iv never use delrin how heavy is it i like weight
04-04-2014, 09:55 PM | #14 |
04-04-2014, 10:01 PM | #15 |
| Re: Testing Interest: Made to order wheels Ok. Axial 8hole replica with slw compatibility. And since they would be delrin, you could put in some brass threaded inserts.
04-04-2014, 10:12 PM | #16 |
04-04-2014, 10:18 PM | #17 |
i like crawler innovations new 6 lug but its not real beadlock could u do that 6-Bolt Performance Wheels - 2.2"; 1" Width; Glue - on; Axial & VP SLW Hub Compatible |
04-04-2014, 10:35 PM | #18 | |
The simplest and least expensive would be round holes. A bit more difficult and a bit more expensive would be straight spokes. Anything more complex than that and the price (and machine time) would start to skyrocket. I wish it weren't that way, but at this point in time it is. If there is time this weekend, I'll get some wheels drawn up to give you guys an idea of what can be done inexpensively. I'm not saying that I am against doing anything else, I just want to try to get everyone on the same page concerning my goals with these wheels, which is to offer simple, affordable, basic beadlocks made in widths and offsets you specify. Going beyond that is possible if you want to go there and I have the capability. | |
04-04-2014, 11:06 PM | #19 |
I really like the idea of these wheels. Make them compatible with axial rings and I'll take a set. |
04-04-2014, 11:08 PM | #20 |
I wanna be Dave Join Date: Dec 2009 Location: Outside DC
Very interesting. Subscribed to see where this process ends up. My first thoughts are "custom" and "width." I think you're on to something here. |
Testing Interest: Made to order wheels - Similar Threads | ||||
Testing Interest ~ Input wanted | Duuuuuuuude | Axial SCX-10 | 3 | 01-25-2014 08:50 PM |
Testing Interest ~ Flip Your Lid! | Duuuuuuuude | Axial SCX-10 | 30 | 11-17-2013 09:55 PM |
Testing interest ~ D-Mount for the LCC | Duuuuuuuude | Team Losi Comp Crawler | 39 | 07-19-2013 08:58 PM |
Testing Interest ~ AR60 D-mount | Duuuuuuuude | Axial Wraith | 20 | 12-21-2012 11:10 PM |
Testing Interest ~ AR60 D-mount | Duuuuuuuude | Axial AX-10 Scorpion | 33 | 12-19-2012 04:54 PM |
