10-14-2014, 10:12 PM | #1 |
Rock Stacker Join Date: Feb 2014 Location: Over There
| 2.2 VP SLW V-2 mounting help !!
I'm trying to mount a set of BFG Krawlers to these wheels with CI deuces wild foams and they mount fairly easily but the bead slips out with a little pull of the tire. I mounted again and a few hours later the beads slipped out again without ever touching them. This is happening on all 4 wheels. Other then gluing is there any tricks to mounting tires to these wheels?
10-16-2014, 06:14 PM | #2 |
Rock Stacker Join Date: Aug 2014 Location: Somerset
| Re: 2.2 VP SLW V-2 mounting help !!
no tricks. How is it slipping out without pulling it. when you tighten it down are you tightening it so the ring and wheel are metal on metal on the inside where you can see?
10-16-2014, 11:25 PM | #3 |
Yea metal on metal all the way around. I ended shaving a hair off the deuces wild side walls and all is good now. The foams was pulling the side wall so tight it was pulling itself out.
10-22-2014, 07:37 PM | #4 |
Quarry Creeper Join Date: Nov 2012 Location: Blue Ridge
I have the slw V2's running rok lox, got the tall foams and still had to cut them apart and cut 1 entire rib section out
10-23-2014, 02:45 AM | #5 |
Newbie Join Date: Jun 2008 Location: Saginaw
What about washing the tires to get the mold release off and make them stickier?
2.2 VP SLW V-2 mounting help !! - Similar Threads | ||||
Vanquish SLW wheel hub wheel mounting screws? | chevyfan3 | Tires and Wheels | 6 | 05-16-2013 04:43 PM |
Mounting Chisels With Memory Foam On VP SLW V3's | Dini | Tires and Wheels | 12 | 07-10-2012 03:03 AM |
Mounting SLW hub on xr10 wheel | dogzpolo | Tires and Wheels | 6 | 02-18-2012 09:48 AM |
AX Link and shock mounting, Vs Berg mounting locations. | BEELZEBOB | Axial AX-10 Scorpion | 4 | 06-09-2009 04:04 PM |
