10-28-2014, 11:42 AM | #1 |
Rock Stacker Join Date: Sep 2014 Location: Conway
| Foam question
I am working on a slightly modded Exceed maxstone 16. I purchased Losi MRC wheels and did the beadlock mod. I am running x lock tires and the gray foams that came with them. They seem like they don't flex as much as they should based on how soft the tires are. The tires seem too full? With the added diameter of the rim from the beadlock mod, shoul I trim the foams on the inside diameter or should I trim the outside? Star pattern on the outside? Any advice is appreciated greatly. bellersteven's Library | Photobucket |
11-03-2014, 02:20 PM | #2 |
Newbie Join Date: Sep 2014 Location: canada
| Re: Foam question
Star cut your foams to start if still too stiff then u can trim back the points of the stars
Foam question - Similar Threads | ||||
Tire foam question. WARNING!!! Noob question! | tokdl | Tires and Wheels | 6 | 05-07-2014 10:55 AM |
foam question | putzee | Tires and Wheels | 4 | 07-03-2010 10:43 AM |
To foam, or not foam, that is the question. | Dollarhide | Axial SCX-10 | 10 | 01-23-2010 06:30 PM |
Foam question ... | dude26 | Tamiya Clod Buster | 15 | 03-25-2009 12:39 PM |
Foam question | AlmstEvil665 | Maryland | 3 | 03-05-2009 04:47 PM |
