09-18-2015, 05:15 AM | #21 |
I joined the Band! Join Date: May 2006 Location: Between a rock and a hard spot!
| Re: Axial Yeti XL kit 1/5 wheel conversion Last edited by twissted; 09-18-2015 at 05:17 AM. |
09-30-2015, 09:02 AM | #22 |
Newbie Join Date: Aug 2015 Location: Denmark
My XL with Losi DBXL wheels. Last edited by Limkilde; 09-30-2015 at 09:08 AM. |
09-30-2015, 09:48 PM | #23 |
Sweet setup with the wheel and tires. How do they work for you? I hope more people post there tire and wheel setup here. Thank you for sharing! |
09-30-2015, 10:01 PM | #24 |
I use mine mostly for bashing and for thath they are perfect.
10-02-2015, 07:45 AM | #25 |
| Re: Axial Yeti XL kit 1/5 wheel conversion |
04-13-2016, 09:29 AM | #26 |
When you figure out how to cut and mount the 3.8 tire to the 1/5 rim you will need to use a 24 or 23mm hex adapter to use these wheels. 1/8 ALUM 23MM HEX WHEEL HUB SILVER TRUCK Don't look at other adapters because the wheels are thicker and you need extra thread to mount the wheel nut to the hex adapter. These have that to mount 1/5 beadlock rims. If it is not a 8mm shaft that your mounting the wheel adaptwer but the Traxxas size 6mm them the HPI Savage 24mm wheel adapter is what your looking for. HPI Racing Part # 102530 Aluminum Wheel Hex Hub Set 24mm (Gray/4pcs) For Savage. |
04-13-2016, 10:30 AM | #27 |
RCC Addict Join Date: Jan 2016 Location: Bar Harbor
Thanks for the tip !! I've been looking at this option without knowing the difference ! Thanks
04-07-2017, 02:52 AM | #28 |
Newbie Join Date: Aug 2016 Location: Los Angeles
Does anyone have a picture of the Mud Slingers and where they cut to mount on the 1/5 Rovan 5b rear wheels?
Axial Yeti XL kit 1/5 wheel conversion - Similar Threads | ||||
Axial Yeti XL Kit - My first kit build | vashan | Axial Yeti XL | 19 | 09-01-2015 04:46 PM |
