07-21-2015, 11:40 PM | #1 |
I joined the Band! Join Date: May 2006 Location: Between a rock and a hard spot!
| Axial Yeti XL kit 1/5 wheel conversion
Parts needed; http://www.imex-model.com/product/RC...VER-TRUCK.html Custom (Very Limited) 23mm hex wheels that fit the 1/5 beadlocks Heavy Duty Nylon 10 Spoke Rims and Beadlocks (set of (orange) WILL NOT FIT 24MM BAJA HUBS!! He also has narrow 1/5 Paddle tires and wheels that work great on this conversion. Rear Truck Sand Paddle Wheels (set of 2) He ships free in the USA! Last edited by twissted; 04-13-2016 at 09:21 AM. |
07-21-2015, 11:43 PM | #2 |
| Re: Axial Yeti XL kit 1/5 wheel conversion |
07-21-2015, 11:45 PM | #3 |
| Re: Axial Yeti XL kit 1/5 wheel conversion Last edited by twissted; 07-22-2015 at 06:18 PM. |
07-22-2015, 12:06 AM | #4 |
07-22-2015, 12:10 AM | #5 |
I thought show and tell was over?
07-22-2015, 12:11 AM | #6 |
07-22-2015, 12:13 AM | #7 |
07-22-2015, 12:18 AM | #8 |
It's kinda cool that poeple want to put parts on this build. I hope it keeps up!
07-26-2015, 10:51 AM | #9 |
Nice option. Can you confirm weight of the wheel ? Thanks for any information.
07-26-2015, 11:15 PM | #10 |
| Re: Axial Yeti XL kit 1/5 wheel conversion I'll look into it. I can tell you now that they are very thick and weigh more. You will not break or bend them. It is also the reason that the wheel adapters that you use has a long neck so that the nut has room to lock down as it should. the wheel nut also has a ruber O-ring in it. They are lighter in weight than the 40 series aluminum wheels that RC4WD sells. these wheels are made to hold up to my Losi 5ive that weighs 40 pounds!
07-28-2015, 10:47 AM | #11 |
Nice Yeti XL option, so far every other beadlock wheel has been way too wide.
07-29-2015, 06:44 PM | #12 |
There is more to come! I have some of the orange 5 spoke wheels with the metal insert just like the Losi 5ive wheels but they have a better off-set to get a little wider stace. Nylon Orange Wheel Rim Set for 1 5 Baja HPI KM Rovan RC Car | eBay I ordered 2 sets so that I hve 4 wide rims and also 4 narrow rims. I need the wide rims for the paddle tires that Im going to run from RC4WD. I will then doa sand tire test of the best tires out. I'm pretty shure it will be the Top Secret Racing Paddles that will come out on top. I'm not counting out the RC4WD Sand Storm tires though. |
07-29-2015, 07:01 PM | #13 |
If your looking to add lights then... This is what I found that holds up and doesn't break the bank! Electrical: Rovan RC Last edited by twissted; 07-29-2015 at 07:05 PM. |
08-04-2015, 01:18 PM | #14 | |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
| Re: Axial Yeti XL kit 1/5 wheel conversion Quote: thanks | |
08-05-2015, 04:20 PM | #15 |
I don't have a proper scale to weigh the rims and tires.
08-09-2015, 01:20 AM | #16 |
Pebble Pounder Join Date: May 2014 Location: Floriduh
I bought a set of Rok Lox to put on the XL but I thought they were way too big to really run on the rig without steering into the body. Maybe I should just glue them up to the kit wheels after all!
08-10-2015, 04:06 AM | #17 |
I don't have that problem with this wheel/tire combo. I also use a Summit transmission in this build so gearing is good also. Last edited by twissted; 08-10-2015 at 04:09 AM. |
08-16-2015, 11:00 PM | #18 |
This is my favorite tire and wheel combo. The tires don't need foam inside due to the stiff side walls. The 1/5 Rovan 5 spoke beadlock (rear) wheels also have the wheel back space that makes these wheels work so well. Last edited by twissted; 08-19-2015 at 10:07 AM. |
08-24-2015, 10:47 AM | #19 |
09-04-2015, 09:57 AM | #20 |
Axial Yeti XL kit 1/5 wheel conversion - Similar Threads | ||||
Axial Yeti XL Kit - My first kit build | vashan | Axial Yeti XL | 19 | 09-01-2015 04:46 PM |
